Author Topic: Can you run a 35w Sox lamp on a 55w ballast?  (Read 2131 times)
Streetlightsandlamps
Thorn gamma 6
Can you run a 35w Sox lamp on a 55w ballast? « on: August 19, 2024, 01:20:43 AM » Author: Streetlightsandlamps
I would like to know if you can run a 35w Sox lamp on a 55w Sox ballast? This is because I have a lantern that has a 55w ballast, the lantern is a thorn gamma 6, but it can only fit a 35, 26, 18w lamp. I don’t want to risk damaging a lamp, ballast or ignitor.
Sox is the best
LED is the worst
If you would like to see my website, here is the link: https://www.streetlightsandlamps.com/
Re: Can you run a 35w Sox lamp on a 55w ballast? « Reply #1 on: August 20, 2024, 07:49:05 PM » Author: wide-lite 1000
 Not sure about the UK ballasts but I know the US spec SOX ballasts are rated for both .
Re: Can you run a 35w Sox lamp on a 55w ballast? « Reply #2 on: August 21, 2024, 04:16:21 AM » Author: dor123
Is the ballast have taps for 35W and 55W?
Thorn gamma 6
Re: Can you run a 35w Sox lamp on a 55w ballast? « Reply #3 on: August 21, 2024, 07:09:20 AM » Author: Streetlightsandlamps
I actually didn’t look at the ballast properly, it is actually for 35/55w SOX lamps. :)
Sox is the best
LED is the worst
Re: Can you run a 35w Sox lamp on a 55w ballast? « Reply #4 on: August 21, 2024, 07:21:50 AM » Author: dor123
I would expect the ballast to have separate taps for 35W and 55W SOX lamps, similar to a MV ballast for 80/125W or a HPS ballast for 100/150W.
Al_M
GEC Z9464 90w SOX/LPS
Re: Can you run a 35w Sox lamp on a 55w ballast? « Reply #5 on: August 21, 2024, 05:48:03 PM » Author: Al_M
@dor123 The choke ballasts for 35w/55w SOX lamps don't have two different taps for the two sizes.
Re: Can you run a 35w Sox lamp on a 55w ballast? « Reply #6 on: August 22, 2024, 12:47:54 AM » Author: James
I would generally agree, most ballast have no different taps for 35/55W but there are some exceptions.  The May & Christie NA85 does have separate taps, and there was also at least one GEC ballast (with integrated ignitor) with dual taps.  It is not needed for correct lamp operation, but I think enabled a small increase in ballast efficacy.
Re: Can you run a 35w Sox lamp on a 55w ballast? « Reply #7 on: August 22, 2024, 02:23:24 AM » Author: wide-lite 1000
In the US , Both the 35/55w and the 135/180w Sox ballasts will run either lamp without separate taps for either wattage .
