Author Topic: 12/24V incandescent lamp in series with MV lamp on solar or wind power  (Read 1657 times)
Milwaukeeman2003
SRX
Fat Squidward Milwaukeeman2003
12/24V incandescent lamp in series with MV lamp on solar or wind power « on: August 06, 2024, 12:09:22 PM » Author: Milwaukeeman2003
Hello everyone! I was just wondering if it is possible to run an MV lamp of any wattage in series with a 12V incandescent lamp. Any information would be greatly appreciated. Thanks!
« Last Edit: August 06, 2024, 12:11:43 PM by Milwaukeeman2003 » Logged
Screw the 2028 120 lumen per watt mandate and DeviantArt! Love old cars, cassette tapes, radios, severe weather and most of all, lighting!
Re: 12/24V incandescent lamp in series with MV lamp on solar or wind power « Reply #1 on: August 06, 2024, 01:08:29 PM » Author: RRK
For which purpose? As a sole ballast, no, you need to drop about 1/2 of line voltage on the ballast, may be a little bit less, for discharge lamp to work properly. If you have other means for ballasting, and the current is right - why not?
Milwaukeeman2003
SRX
Re: 12/24V incandescent lamp in series with MV lamp on solar or wind power « Reply #2 on: August 06, 2024, 11:04:28 PM » Author: Milwaukeeman2003
Thanks for the info! I was thinking of such a project for my grandmothers yard as there are criminals in her area and she’s been taking care of my great grandmother who has dementia.
Re: 12/24V incandescent lamp in series with MV lamp on solar or wind power « Reply #3 on: August 07, 2024, 04:21:25 AM » Author: Medved
Plus (I guess you are from the US, so 120V area) the MV has arc voltage a bit above 110V, so you would need 220..240V to run it just in series with an incandescent.
So it may work in 230V mains Europe, but not in 120V North America.
And definitely if your only supply is 12 or 24V, you would need a special ballast/inverter (e.g. like this) for the lamp anyway, so then no incandescent or so would be needed.
Milwaukeeman2003
SRX
Re: 12/24V incandescent lamp in series with MV lamp on solar or wind power « Reply #4 on: August 07, 2024, 01:01:50 PM » Author: Milwaukeeman2003
Thanks for the info! I do live in the US so sadly undoable.
Re: 12/24V incandescent lamp in series with MV lamp on solar or wind power « Reply #5 on: August 07, 2024, 01:54:08 PM » Author: RRK
But you sure may hook an inverter to photovoltaic system DC output (if it is not already in place) and then power just whatever lamps you wish.
Milwaukeeman2003
SRX
Re: 12/24V incandescent lamp in series with MV lamp on solar or wind power « Reply #6 on: August 07, 2024, 02:12:30 PM » Author: Milwaukeeman2003
Cool!
