Author Topic: Wanted: Clear 100 watt mogul base mercury lamp  (Read 3122 times)
lightinggalleryuser33450
Wanted: Clear 100 watt mogul base mercury lamp « on: July 22, 2024, 03:24:42 PM » Author: lightinggalleryuser33450
I a fixture that uses a 100 watt Mercury Vapor lamp with a mogul base I want an unused clear bulb for it.
Re: Wanted: Clear 100 watt mogul base mercury lamp « Reply #1 on: July 22, 2024, 03:26:10 PM » Author: WorldwideHIDCollectorUSA
Here is a nice vintage lamp that should help serve your needs:
https://www.ebay.com/itm/186340899910
Re: Wanted: Clear 100 watt mogul base mercury lamp « Reply #2 on: August 02, 2024, 06:15:23 PM » Author: lightinggalleryuser33450
Works great, thanks
Re: Wanted: Clear 100 watt mogul base mercury lamp « Reply #3 on: August 02, 2024, 06:16:24 PM » Author: WorldwideHIDCollectorUSA
What a nice CWA ballast flash pattern!!!
arcblue
Re: Wanted: Clear 100 watt mogul base mercury lamp « Reply #4 on: August 24, 2024, 06:15:58 PM » Author: arcblue
Those Sylvanias are gorgeous. I ended up getting one for my light out front as it looks better in an open bottom fixture than the ED shaped Iwasaki.
I'm lampin...
