LightsAreBright27
![](https://www.lighting-gallery.net/index.php?PHPSESSID=ecb583b17d895633195a6ae91ababbd9&action=dlattach;attach=14329;type=avatar)
Cheap LED Assassin
I am sorry if this is a cliché question, but I am a new person to HID lamps.
I have a ballast for 400w lamps. It says it is for hps/mh, but also has mv base. Current - 2.10a Voltage - 240v 50hz There is also an ignitor inside the ballast with separate compartment, a three wire one (red, yellow & black). So it says no ignitor.
I won't be running the lamps for very long, only a short test of about however long it takes to warm up. I have- HPS 400w MH 400w (4 of them with unknown base, MV or not) MV 400w
Also, is there any other precaution while running the lamps?
Holder of the rare and sacred F10T12/BL lamps here! Also known as LAB27 for short. One of the only Indian members here! 245v 50Hz
![](https://www.lighting-gallery.net/index.php?PHPSESSID=ecb583b17d895633195a6ae91ababbd9&action=dlattach;attach=12855;type=avatar)
The ballast states HPS/MH, which means that it can operate HPS and MH lamps that are designed to HPS ballast like Osram HQI-BT 400W/D or Philips HPI-T Plus and GE Arcstream.
LightsAreBright27
Cheap LED Assassin
How many of these could it run?
I think it can run all of these, except the MV lamp which would be overdriven. You need an ignitor.
LightsAreBright27
Cheap LED Assassin
What kind of ignitor exactly? Can I run the MV for a short time (10 mins?)?
HPS and MH ignitors. You can run the MV lamp for a short time.
LightsAreBright27
Cheap LED Assassin
The ballast has a 3 wire ignitor already inside. Thanks for the help!
It is always a gamble with off-brand metal halide lamps if they are sodium (4A) or mercury (3.25A) ballast rated. 3-electrode MH lamps are generally expected to be mercury ballasted, no way to predict for 2-electrode ones. More, even sodium ballasted MH lamps often (but not all!) run at higher than HPS burner voltage, so actual ballast current falls in some 3.4-3.7A range in fact.
