Author Topic: What Fulham ballast should I use for a 35w Sox lamp?  (Read 3963 times)
Bulbman256
Mad Max
Bulbman256
What Fulham ballast should I use for a 35w Sox lamp? « on: July 01, 2024, 03:59:23 AM » Author: Bulbman256
Hello everyone,
I have recently aquirered a 35w Sox lamp and am looking for a ballast for the thing. I remember that you can use a Fulham ballast on them but I cannot remember what model number to use. If you know, please do tell me. 8) :lps:
Econolite03
Matthew E.
Re: What Fulham ballast should I use for a 35w Sox lamp? « Reply #1 on: July 01, 2024, 05:41:00 AM » Author: Econolite03
Fulham Workhorse 3 (WH3-120-C).
Re: What Fulham ballast should I use for a 35w Sox lamp? « Reply #2 on: July 01, 2024, 02:17:46 PM » Author: joseph_125
Thanks for the tip, I have a couple 35w SOX lamps but no ballast or fixture for them.
fluorescent lover 40
Re: What Fulham ballast should I use for a 35w Sox lamp? « Reply #3 on: July 01, 2024, 02:22:33 PM » Author: fluorescent lover 40
I know this topic is talking about a 35w lamp, but what Fulham would be good for a 55w one? I happen to have one without a ballast.
Econolite03
Matthew E.
Re: What Fulham ballast should I use for a 35w Sox lamp? « Reply #4 on: July 01, 2024, 05:58:26 PM » Author: Econolite03
Not sure on the size for 55, or even the 90W lamps.
Here are the proven / confirmed Workhorse sizes for LPS lamps:
WH2 = 18W
WH3 = 35W
WH8 = 135W, 180W
Re: What Fulham ballast should I use for a 35w Sox lamp? « Reply #5 on: July 02, 2024, 04:15:39 AM » Author: funkybulb
35 watt LPS u dont even really need a expensive fulham workhourse ballast.  I have Run a 35 watt LPS on 32 watt instant start ballast With both output tied together and it works great.
Bulbman256
Mad Max
Bulbman256
Re: What Fulham ballast should I use for a 35w Sox lamp? « Reply #6 on: July 05, 2024, 12:59:24 PM » Author: Bulbman256
Thanks funkybulb, I tried that and it worked great. I just need to get a current meter out and check that it is within spec tonight. 8)
