Author Topic: How to Fix a Fluorescent Light  (Read 2809 times)
How to Fix a Fluorescent Light « on: June 17, 2024, 03:31:19 PM » Author: rjluna2
I found online article about How to Fix a Fluorescent Light.  Opinions?
Re: How to Fix a Fluorescent Light « Reply #1 on: June 18, 2024, 01:28:37 AM » Author: Medved
That is nonsense.
The florescents start flickering and even the starter get damaged (90% of the time) from the tubes alone running EOL in the first place. So replacing the starter does not solve problem, It may hide the symptoms for a while (new starters may have the triggering voltage a bit higher, so still run the lamps in that state for a while without interfering), but the consumed cathodes will just make the symptoms return pretty quickly back again.
Re: How to Fix a Fluorescent Light « Reply #2 on: June 18, 2024, 07:23:45 AM » Author: rjluna2
There's more to do with repairing the fluorescent light bulbs :lol:
Re: How to Fix a Fluorescent Light « Reply #3 on: June 19, 2024, 01:33:10 PM » Author: WorldwideHIDCollectorUSA
In preheat fluorescent luminaires, it is common practice to replace starters and tubes together.
