Author Topic: American Electric 315 Power Pad CMH conversion  (Read 1964 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
American Electric 315 Power Pad CMH conversion « on: May 15, 2024, 10:37:44 PM » Author: HIDLad001
I am looking to convert an AEL series 315 to run 150w G12 base CMH lamps with an electronic ballast. It should be pretty easy to mount the ballast on the power pad and rewire everything, but how should I go about making a CDM-T lamp compatible with the existing (FCO) optical assembly? Should I make a bracket that extends the lampholder out or maybe at an angle?
Any help will be appreciated.
Re: American Electric 315 Power Pad CMH conversion « Reply #1 on: May 15, 2024, 11:33:13 PM » Author: joseph_125
I did a conversion on a Holophane Bantam 2000 to 39w CMH at one point. I made a small bracket to adapt the existing medium base lampholder mounting holes to a G12 lampholder. As for the height, I made it so it roughly matched the arc tube on the 175w MH it was originally designed for.
Note that there also exist E26 to G21 screw in adapters. However the plastic on mine wasn't suitable for the heat of a 150w CMH lamp
Re: American Electric 315 Power Pad CMH conversion « Reply #2 on: May 16, 2024, 08:45:49 AM » Author: Mandolin Girl
I'd never trust one of those el-cheapo adaptors, no matter what the rating of the lamp.! ???
BT25
Re: American Electric 315 Power Pad CMH conversion « Reply #3 on: May 16, 2024, 07:25:29 PM » Author: BT25
Swapping the ballast would be rather easy...the lamp, not so much. How about making it easier on yourself and get a Philips MasterColor CDM150/U/PS/4K CMH lamp? These have an E39 mogul base. I've used these with standard magnetic ballasts that run M102 lamps...no issues. Also compatible eHID ballasts.
HIDLad001
Re: American Electric 315 Power Pad CMH conversion « Reply #4 on: May 16, 2024, 07:42:43 PM » Author: HIDLad001
I would really like one of those if it was available in 3000K. Did they ever make mogul base ceramic metal halide lamps in 3000K?
BT25
Re: American Electric 315 Power Pad CMH conversion « Reply #5 on: May 16, 2024, 08:44:29 PM » Author: BT25
Unfortunately, no...these are 4000K, 90% + CRI...they're actually really nice lamps. The high CRI doesn't have that annoying blue content when compared to cheap QMH lamps.
Re: American Electric 315 Power Pad CMH conversion « Reply #6 on: May 16, 2024, 09:41:02 PM » Author: joseph_125
I suppose you could find a pulse rated mogul to medium reducer (they exist, just a bit harder to find) and then pair it with a ED17 3000K CMH lamp. The would be the simplest way.
HIDLad001
Re: American Electric 315 Power Pad CMH conversion « Reply #7 on: May 16, 2024, 10:02:08 PM » Author: HIDLad001
But I kind of want a somewhat official one with a real G12 base and custom bracket, kind of like the Chicago spec M250s in CMH (but those have a different base). Besides, I could use the mogul socket and the old ballast to convert another light to HPS.
Re: American Electric 315 Power Pad CMH conversion « Reply #8 on: May 16, 2024, 10:07:55 PM » Author: joseph_125
Fair enough. I used some 1/2" 1/16" thick aluminum bar stock to make the bracket for my Bantam. Drilled and tapped holes for mounting and then used a vise and a small bending die set to make the bends.
HIDLad001
Re: American Electric 315 Power Pad CMH conversion « Reply #9 on: May 17, 2024, 08:38:14 AM » Author: HIDLad001
Could you upload a picture?
