Author Topic: Retrofit sodium lamp questions...  (Read 1900 times)
Multisubject
All lights are created equal
Retrofit sodium lamp questions... « on: April 14, 2024, 05:31:17 PM » Author: Multisubject
I might get a retrofit sodium lamp, but they say they can't be run on CWA ballasts. I have a few questions:
1: What would really happen if you ran it on a CWA ballast?
2: If the CWA ballast would overdrive the HPS lamp, could I lower the wattage by substituting in a lower series capacitor?
Thank you for any help :hps:
Robotjulep
HID lighting is the best lighting!
Re: Retrofit sodium lamp questions... « Reply #1 on: April 14, 2024, 11:44:50 PM » Author: Robotjulep
If the HPS retrofit lamp you are talking about is the "penning-start" type such as Sylvania Unalux, then it will harm both CWA ballast as well as the lamp. This is due to those HPS retrofit lamps not being able to handle constant current from a CWA. I recommend running these on HX-HPF or reactor ballasts. Only problem is that HX-HPF ballasts are rarer than CWA.
On the other hand, there are HPS retrofit lamps such as Phillips Retrolux and EYE Iwasaki Super Ace that feature "glowbottle" ignitors built into the lamp. These can be ran on CWA no issues. Unfortunately, these "glowbottle" HPS lamps are generally more expensive and harder to find.
Last but not least, there are HPS retrofit lamps as well as metal halide lamps that retrofit mercury vapor. They are compatible only with HX-HPF and Reactor ballasts. They utilize a built-in "FEC" ignitor to start the lamp. The FEC ignitor looks like a round brown disk with terminals.
Re: Retrofit sodium lamp questions... « Reply #2 on: April 15, 2024, 02:22:28 AM » Author: Medved
The ballast compatibility is published on the lamps datasheet. If the lamp is rated as compatible with a given ballast type, there should not be any issue.
Whether a penning mixture, or any other HPS lamp is compatible with a constant current CWA ballast does not have to always be related to the lamp chemistry itself, but also to the lamp construction, especially its thermal management.
The fact is the constant current ballasts combined with a saturated vapor lamp in its basic form does lead to thermal instability (hither temperature -> higher pressure -> higher voltage drop -> higher power -> higher temperature positive feedback), but manufacturers came with design tricks to eliminate that sufficiently enough so the lamp becomes stable even on a CWA ballast. One example is to put the amalgam reservoir (aka from the vapor pressure perspective the "cold spot" whose temperature dictates the operating pressure) further away from the active arc, so suppressing the thermal feedback, but that is not the only one.
So the question is, whether any such thermal feedback suppression is used in the lamp design and whether it is effective enough to make the lamp really stable so compatible with the constant current drive of a CWA ballast.
From marketing perspective, if a big portion (maybe even a majority) of MV ballasts on the target market are the constant current drive CWA type, I would be very surprised any lamp maker would make a lamp advertised as a "MV replacement" without making sure its design is compatible with the CWA ballast.
Of course very different situation would be when you import the retrofit lamp from a "230V" area where series chokes are 99% of the MV ballasts in use, so where the saturated vapor lamp is stable by itself, so without any such thermal feedback suppression feature. Then you have to really make sure the ballast has the same or similar characteristics as the original series choke (so e.g. the HX transformer or so).
LightBulbFun
Re: Retrofit sodium lamp questions... « Reply #3 on: April 15, 2024, 03:03:02 AM » Author: LightBulbFun
you say that, but the first generation of HPS retrofit lamps sold in the US where indeed incompatible with CWA ballasts, it was one of the big limiting factors when it came to the wide spread adoption
if you look up the GE E-Z-Lux and Sylvania Unalux, you will see how their entries in the catalogs and such like are plastered with warnings about being suitable for operation only on HX-Autotransformer or Choke type ballasts
the other main problem is besides general instabilities as your describe is that at the end of life the voltage of a HPS lamp rises and on a constant current ballast like a CWA ballast, this can lead to dangerously high power levels
it was not until unsaturated HPS lamps where devloped did CWA compatible HPS retrofit lamps become possible
dedicated CWA HPS ballasts I understand work around the issue by having a very low OCV, so the lamp arc voltage cannot rise that much before it exceeds what the OCV can support and the end of life lamp will thus safely cycle
Re: Retrofit sodium lamp questions... « Reply #4 on: April 15, 2024, 06:34:17 AM » Author: Medved
Definitely what matters is what the thing is really rated for by the manufacturer, ANY assumption or expectation just by itself could be completely wrong...
Multisubject
Re: Retrofit sodium lamp questions... « Reply #5 on: April 17, 2024, 10:00:59 PM » Author: Multisubject
Thanks for letting me know! I was ready to try it but now I won't. If only HX ballasts were more common...  :-\
Re: Retrofit sodium lamp questions... « Reply #6 on: April 17, 2024, 10:04:38 PM » Author: wide-lite 1000
 I killed my Sylvania 880w Retrofit lamp by running it from a CWA ballast . It ran for about 10 min. before it started cycing .
« Last Edit: May 11, 2024, 09:32:49 AM by wide-lite 1000 » Logged
Re: Retrofit sodium lamp questions... « Reply #7 on: April 18, 2024, 12:24:05 AM » Author: icefoglights
HX ballasts are quite common, depending on the application.
Re: Retrofit sodium lamp questions... « Reply #8 on: May 09, 2024, 05:26:42 AM » Author: WorldwideHIDCollectorUSA
In North America, they are pretty rare above 250W and especially hard to find in 1000W H36 mercury vapor versions. As far as I know, the 175W H39 mercury vapor HX autotransformer ballasts are the most common North American mercury vapor HX autotransformer ballasts as they are often found in yardblaster fixtures and NEMA head fixtures with bucket style refractors. On a positive note, I am a very proud owner of a rare Jefferson Electric 400W H33 mercury vapor high power factor HX autotransformer ballast. With that ballast, I was able to run some neon argon penning high pressure sodium retrofit lamps that I had sitting in my collection that luckily were not killed after shortly experimenting with them on CWA ballasts, but now that I have the proper HX autotransformer ballast designed for them, I can enjoy running them for longer periods of time.
« Last Edit: May 09, 2024, 05:31:52 AM by WorldwideHIDCollectorUSA » Logged
Re: Retrofit sodium lamp questions... « Reply #9 on: May 11, 2024, 09:35:30 AM » Author: wide-lite 1000
 Older Wite-Lite F-series and Westy OV-400's all had H-33 HX ballasts so did a lot of 400w MV NEMAs
Re: Retrofit sodium lamp questions... « Reply #10 on: May 11, 2024, 09:57:12 AM » Author: joseph_125
I think 250w and 400w HX ballasts weren't too uncommon during the heyday of MV as certain types of fixtures had them or was a option for some others. 175w was just more common as about every 175w MV yardlight used a HX ballast.
HX ballasts seemed to be pretty hard to find standalone though. A lot of aftermarket kits were CWA, although the NEMA specific kits were all HX.
