Author Topic: Working fixture with Westinghouse circlarc lamps  (Read 6109 times)
Working fixture with Westinghouse circlarc lamps « on: March 02, 2024, 02:04:51 AM » Author: WorldwideHIDCollectorUSA
Not too many of these fixtures and lamps around:
https://youtu.be/63Zmt8IaBEQ?si=N0xaCG61vAy6IqrB
LightsAreBright27
Cheap LED Assassin
Re: Working fixture with Westinghouse circlarc lamps « Reply #1 on: March 02, 2024, 02:46:30 AM » Author: LightsAreBright27
I like how they used two circlarc tubes instead of a circline tube ( :circarcfl:+ :circarcfl:= :circ:). I am still curious why they decided to do so.
« Last Edit: March 02, 2024, 02:48:46 AM by LightsAreBright27 » Logged
245v 50Hz
Re: Working fixture with Westinghouse circlarc lamps « Reply #2 on: March 02, 2024, 02:48:38 AM » Author: WorldwideHIDCollectorUSA
This was an early attempt to make a round fluorescent fixture where the lamps are semicircle lamps rather than fully round fluorescent lamps like circline fluorescent tubes. These lamps were only produced for a very short time.
LightsAreBright27
Cheap LED Assassin
Re: Working fixture with Westinghouse circlarc lamps « Reply #3 on: March 02, 2024, 02:51:58 AM » Author: LightsAreBright27
If this has two ballasts, it would be better than a single circline. You could turn one off ,use different colours (if the idea of these lasted long enough to make different types), or if one was EOL, the other would still work. I am not sure about the availability of these tubes, even at that time.
245v 50Hz
Re: Working fixture with Westinghouse circlarc lamps « Reply #4 on: March 02, 2024, 10:25:32 AM » Author: WorldwideHIDCollectorUSA
As far as I understand, these early fluorescent fixtures typically used 2 ballasts.
Philips tigkas
Re: Working fixture with Westinghouse circlarc lamps « Reply #5 on: March 09, 2024, 05:46:11 AM » Author: Philips tigkas
Are these semi circle tubes?
LEDs are like an apocalypse! They slowly take over the world wiping out every other type of lamp and fixture!
Re: Working fixture with Westinghouse circlarc lamps « Reply #6 on: March 09, 2024, 05:46:59 AM » Author: WorldwideHIDCollectorUSA
These are lamps that are shaped like 180 degree arcs.
Philips tigkas
Re: Working fixture with Westinghouse circlarc lamps « Reply #7 on: March 09, 2024, 12:58:10 PM » Author: Philips tigkas
Wow well that's interesting! I've never seen such thing before. :o Looks so cool though! :bulbman:
Re: Working fixture with Westinghouse circlarc lamps « Reply #8 on: March 16, 2024, 04:25:05 AM » Author: HomeBrewLamps
How do the sockets work? Are they some sort of press fit thing or do the tubes just sit in them?
~Owen
Richmond2000
120V 60HZ
Re: Working fixture with Westinghouse circlarc lamps « Reply #9 on: March 16, 2024, 02:06:54 PM » Author: Richmond2000
saw a single circarc "TV console" light had a glass shade and one circarc lamp pins down behind the shade
found it MANY years ago at a charity shop did NOT buy it
Re: Working fixture with Westinghouse circlarc lamps « Reply #10 on: July 02, 2024, 04:57:55 AM » Author: funkybulb
That happens to be my channel.
Many of these fixture got thrown out
When  home owners finds out the
Lamps were no longer made.  I just
Happen to got this on Ebay locally
And mangage to get extra spare bulbs
For them as well.  The lamp kinda installs
Same way like u do ubend tubes.
