Author Topic: step dimming ballasts  (Read 2760 times)
Alights
USA (120V 60HZ)
step dimming ballasts « on: June 29, 2010, 08:51:51 PM » Author: Alights
I found a really good price on a step dimming
http://cgi.ebay.com/GE-B132R277S50-1-LAMP-DIMMING-ELECTRONIC-START-BALLAST-/350359629215?cmd=ViewItem&pt=BI_Security_Fire_Protection&hash=item51930fad9f
this ballast uses 2 switches if both are on, then 100% lamp output, 50% output for one switch
it has NO EOL protection, which could be interesting
see this also
http://www.unvlt.com/productLines/ap_sheets/ELFB/B132R277S50.pdf
sorry about the URL! i never learned "the right way to do it"
Luminaire
Re: step dimming ballasts « Reply #1 on: June 29, 2010, 09:49:33 PM » Author: Luminaire
see this also
It's an older dedicated voltage ballast.  1 x 32W, 277v input.
It looks like step dimming ballasts are using two switches now a days. Advance used to make something interesting.  It was a four lamp ballast with 4 lamp on startup, then rapid power cycling makes it switch to 2 lamp.
http://www.brite-lite.com/Pdf/Form1939.pdf
