Author Topic: How do i clean a bulb without removing etching?  (Read 836 times)
wharinterrobang
Old whatever enthusiast
How do i clean a bulb without removing etching? « on: January 26, 2024, 07:43:39 PM » Author: wharinterrobang
Title says alot!!!
Re: How do i clean a bulb without removing etching? « Reply #1 on: January 27, 2024, 06:07:15 PM » Author: wide-lite 1000
 I just carefully clean around the etch .
Maxim
Filament LEDs. Both a blessing and a curse.
Re: How do i clean a bulb without removing etching? « Reply #2 on: January 27, 2024, 08:39:38 PM » Author: Maxim
I typically use a damp paper towel or cloth and lightly run it over the etch area. Typically, I only lose etches if my skin directly contacts the etch; I believe oils in the skin cause this, but I'm not entirely sure.
But, if your tube or lamp is extremely valuable to you, do what Tim (Wide-Lite) said, just in case.
The Westinghouse Lifeguard Disease, it's here. All ye, proceed with caution.
Re: How do i clean a bulb without removing etching? « Reply #3 on: January 27, 2024, 08:49:07 PM » Author: wide-lite 1000
 I killed one with windex and a paper towel .  :(
« Last Edit: February 29, 2024, 04:42:46 PM by wide-lite 1000 » Logged
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
Re: How do i clean a bulb without removing etching? « Reply #4 on: February 26, 2024, 11:14:51 PM » Author: 108CAM
I usually use a damp cloth or paper towel to clean the parts with no etching then use a cotton tip to clean around the etch.
The cotton bud method also works really well for cleaning the small gaps between the tubes of CFL and PL lamps.
1925-2002
Bring back the AJF Zodiacs!
Re: How do i clean a bulb without removing etching? « Reply #5 on: February 26, 2024, 11:31:29 PM » Author: RRK
In the times of COVID craze I accidentally found out that synthetic alcohol wipes, cheap at any pharmacy, are also a very convenient and efficient way to clean almost anything, from a fly-ridden refrigerator to lamp surfaces. Gentle on a glass, but MAY remove some poorly made etchings/markings. Now I always keep a box of them just in case.
