Author Topic: Favorite subway/rapid transit car(s)?  (Read 4028 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
Favorite subway/rapid transit car(s)? « on: December 11, 2023, 11:56:10 AM » Author: HIDLad001
My personal favorites have to be the A division New Technology Trains on the NYC subway (R142, R142A, and R188, built by Bombardier and Kawasaki respectively) because of the design with the red accents and the awesome-sounding propulsion systems.
Does anybody else have a favorite subway/rapid transit car, or is it just me?
Re: Favorite subway/rapid transit car(s)? « Reply #1 on: December 11, 2023, 07:14:10 PM » Author: joseph_125
I think most of mine are the now decommissioned rolling stock that the TTC in Toronto used.
Each subclass of the old Hawker Siddeley H series trains was a bit unique, the earlier ones used resistors that were switched in and out of circuit as the train accelerated or braked or from series to parallel while the later H series trains used GTO DC propulsion which made a pretty characteristic sound.
The UTDC ICTS cars that were withdrawn this summer had the most unique propulsion. Detroit and Vancouver still run them. They used GTO inverter LIM propulsion. Unfortunately the tech didn't work that well in the Toronto system.
In terms of trains still in service, the Bombardier T1 are pretty neat, they use AEG-Westinghouse GTO AC inverter propulsion and has a pretty unique acceleration and braking sound.
HIDLad001
Re: Favorite subway/rapid transit car(s)? « Reply #2 on: December 13, 2023, 08:57:45 AM » Author: HIDLad001
I think the ICTS stock is cool too, and I like the design of the T1s. They seem to have similar propulsion to the R110A (Which was build by ADtranz, but isn't the T1's propulsion made by ADtranz, the successor to AEG/Westinghouse and ABB?).
Another one I forgot to mention that I like is the now-retired Washington Metro 1000 series built by Rohr. They had GE GTO propulsion I believe (similar to the R110B and identical to the Breda A650 in LA).
Re: Favorite subway/rapid transit car(s)? « Reply #3 on: December 13, 2023, 07:46:09 PM » Author: joseph_125
I wonder too, the T1 inverter tray I saw opened up had AEG labels on some of the components inside, maybe some of the newer T1s had ADTranz propulsion inside. The last T1s were produced in the 2000s. Interestingly, the TTC also had a IGBT retrofitted inverter tray for the T1, the original inverter tray used GTO.
The T1's design language was strongly influenced by that of the H series, Bombardier Transportation (now Alstom) was the successor to Hawker Sideley. The platform that all those models were based on was known as the RTC-75. Interestingly Montreal's long removed 1960s Expo Express and Ankara's Metro also used RTC-75 derived rolling stock at one point. Ankara's rolling stock was built around the same time as the T1 but resembled the H6 more than the T1.
HIDLad001
Re: Favorite subway/rapid transit car(s)? « Reply #4 on: December 13, 2023, 07:52:34 PM » Author: HIDLad001
Very cool! Do you have any photos of the GTO or IGBT inverter trays?
I believe the Ankara Metro H6 had only one window on the front for the driver's cab.
Re: Favorite subway/rapid transit car(s)? « Reply #5 on: December 17, 2023, 12:55:03 PM » Author: joseph_125
I do, I posted a few pictures of the inverter trays as well as the Westinghouse camshaft propulsion used on the Hawker H4.
HIDLad001
Re: Favorite subway/rapid transit car(s)? « Reply #6 on: December 19, 2023, 05:40:20 PM » Author: HIDLad001
Wow thanks! There is not much information about these things on the internet for some reason.
I assume the cam control works very similar to a timer in an old washing machine, because it looks very similar (just much bigger).
How many of these inverters (or cam controllers) are in each train car? Is there one for each motor?
bulb_tester2009
Re: Favorite subway/rapid transit car(s)? « Reply #7 on: June 26, 2024, 04:25:12 AM » Author: bulb_tester2009
I like Shanghai Metro Line 1 AC06 Alstom train best.
« Last Edit: June 27, 2024, 01:49:37 AM by bulb_tester2009 » Logged
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
Re: Favorite subway/rapid transit car(s)? « Reply #8 on: June 26, 2024, 07:40:25 AM » Author: rjluna2
I used to go on MARTA rail services until I moved to my new home.  My favorite rolling stock are Hitachi CQ311 and AnsaldoBreda CQ312 due to its comfortable seats :)
Re: Favorite subway/rapid transit car(s)? « Reply #9 on: June 26, 2024, 11:36:46 PM » Author: RRK
For me, modern EMUs like Stadler FLIRT, Siemens Desiro and likes...
Re: Favorite subway/rapid transit car(s)? « Reply #10 on: June 26, 2024, 11:50:55 PM » Author: joseph_125
No problem, I took these pictures myself during a open house at one of the maintenance facilities, not to many pictures of the traction systems out there. IIRC the cams were used to switch how the motors were connected to the traction power, the traction resistor grid (also used for electro-dynamic braking)  which was determined the setting of the master controller in the cab. There's simplified explanation of the different motor connection schemes In this video which was shot in the Toronto system and shows the old Hawker H-1 to H-6 fleet. Not entirely sure, I think each car had one cam controller/inverter tray. IIRC the older cars were coupled as A and B cars, one had the air compressor (operated the brakes, doors, and chimes) and the other had the M/A set or static converter (for the lighting (F72T12 fluorescent) and auxiliary AC circuits).
Each car had two air conditioning units, one at each end. The older cars were non air conditioned and had 5 ventilation fans.
HIDLad001
Re: Favorite subway/rapid transit car(s)? « Reply #11 on: June 30, 2024, 01:01:51 PM » Author: HIDLad001
Very interesting how they powered those interior lights. I have heard that old NYC Subway cars used DC off the 3rd rail to power the fluorescent interior lights and had relays to switch the polarity every so often to prevent mercury migration.
I have also found this video that shows an GE MCM-type cam-controller from an old R17 subway car in operation.
Re: Favorite subway/rapid transit car(s)? « Reply #12 on: August 18, 2024, 01:54:25 PM » Author: icefoglights
I wish I'd taken more notice of the DC Metro cars while I was there, but it was only a week.  However, I did spend 3 months riding down on the NYC subways.  My typical morning commute would start on an R46 R train, then transfer to an R68 D train, and finally an R160 F train with Alstom motors.  It was always a thrill hearing the Bombardier motors on a R142A 6 train and would occasionally go out of my way to ride on one.
