Author Topic: 70W HPS Ballast Wiring Help  (Read 1097 times)
Maxim
Filament LEDs. Both a blessing and a curse.
70W HPS Ballast Wiring Help « on: October 18, 2023, 04:09:09 PM » Author: Maxim
Hi all,
Just got my very first HID ballast, from a friend.
It's a Sola Basic 70W S-62 ballast with all wires in the same color (white).
The ballast was previously used, so a good number of connections are already in place. Now I'm left with the line/neutral connections, as well as the lampholder.
PS the black wirenuts in the photo below denote the ballast / lamp ignitor connections. One goes to the large section, whilst the other goes to the small section.
Attached below is a photo. Thanks so very much!!!
« Last Edit: October 18, 2023, 04:34:16 PM by Maxim » Logged
The Westinghouse Lifeguard Disease, it's here. All ye, proceed with caution.
Re: 70W HPS Ballast Wiring Help « Reply #1 on: October 19, 2023, 12:07:26 AM » Author: RRK
Well, this is not the easiest. With a bunch of unmarked white wires even seasoned people can easily get confused. You can look at useful references like https://hid.venturelighting.com/TechCenter/BallastTypes.html for familiar wiring patterns.
By the way, that kind of question definitely deserves a better photo, where all the wires are visible and are spread out in a meaningful way as to be able to trace their origins!
From the picture, this is definitely an (auto)transformer ballast. For a small lamp, most likely just a leakage transformer (HX) or less likely, CWA circuit.
The coil with the most wires should be multi-tap primary. Sometimes, the connection to secondary is at 120V tap. In that case you can easily deduct this. Sometimes no, may be will require a creative play with an ohm-meter.
« Last Edit: October 19, 2023, 12:18:51 AM by RRK » Logged
Re: 70W HPS Ballast Wiring Help « Reply #2 on: October 19, 2023, 04:48:42 AM » Author: WorldwideHIDCollectorUSA
I found an identical ballast just like this one and it contains the wiring diagram to help you make your connections:
https://www.ebay.com/itm/273629086823
Let me know if this diagram seen on the eBay listing helps.
Bottled lightning
Re: 70W HPS Ballast Wiring Help « Reply #3 on: October 23, 2023, 07:46:12 PM » Author: Bottled lightning
Often the labels are printed on the wires.
Maxim
Re: 70W HPS Ballast Wiring Help « Reply #4 on: October 23, 2023, 07:49:15 PM » Author: Maxim
So, I see the wiring diagram, thanks, but how do I read A and all of the other demarcations for said ballast? It looks to be much more complex than that of say a fluorescent lamp, etc.
Bottled lightning
Re: 70W HPS Ballast Wiring Help « Reply #5 on: October 23, 2023, 11:57:18 PM » Author: Bottled lightning
What does the printing on the wires say? I think I see "lamp" on one of the wires going to the black wire nuts.
