Author Topic: Running a single F20T12 on a 1/2xF32T8 instant start ballast?  (Read 841 times)
F40
Running a single F20T12 on a 1/2xF32T8 instant start ballast? « on: October 14, 2023, 01:06:09 AM » Author: F40
What would be the best way to run a single F20T12 on an instant start ballast for 2 F32T8s?
Robotjulep
HID lighting is the best!!!
Re: Running a single F20T12 on a 1/2xF32T8 instant start ballast? « Reply #1 on: October 14, 2023, 11:30:38 AM » Author: Robotjulep
I think the t12 operates at a lower arc voltage than the t8 so t12 and t8 aren't electrically interchangeable. Also, the instant start ballast may overdrive the lamp and sputter the cathodes. Your best option is to get either a magnetic or rapid-start t12 ballast intended for F20T12. I cannot guarantee operating a t12 on a t8 ballast as the lamp may work for a short time but the lifespan will be reduced and the lamp may fail prematurely.
I collect:
Light bulbs, fixtures, and gear,
Electric motors (Preferably AC induction motors),
Computers,
and Stereo equipment.
Re: Running a single F20T12 on a 1/2xF32T8 instant start ballast? « Reply #2 on: October 14, 2023, 03:17:04 PM » Author: joseph_125
For a brief test I'd just wire it up as if the lamp was a F17T8. Most F32T8 ballasts should also run F17T8 lamps.
For long term use I'd get a proper F20 ballast though.
Alights
USA (120V 60HZ)
Re: Running a single F20T12 on a 1/2xF32T8 instant start ballast? « Reply #3 on: November 06, 2023, 03:39:49 AM » Author: Alights
Double up the blue wires for "overdrive" and it'll probably run the lamp near spec. If not switched too often could last a while
