November 23, 2024, 05:40:33 AM
Modern
70W halide MP70 bulb in HPS fixture
Topic: 70W halide MP70 bulb in HPS fixture (Read 705 times)
Raymondo
« on: October 12, 2023, 12:11:18 AM »
Raymondo
I recently saved a 70W MP70 metal halide bulb and I don’t have any metal halide gear that would run it. I’m wondering if I would be able to use this bulb in a 70W metal halide setup I have. I’ve heard these 70 watt bulbs are similar and I often see pot lights around town that have both types of bulbs co-existing. Just wondering if that would work without hurting anything.
Re: 70W halide MP70 bulb in HPS fixture
« Reply #1 on: October 12, 2023, 09:04:20 AM »
Author: Rommie
It would work over here, since HPS and MH are electrically similar for the most part. I'm not sure about your side of the pond, though
I recommend posting this in the gallery rather than the forum, it'll probably get a wider audience there.
Richmond2000
120V 60HZ
« Reply #2 on: October 12, 2023, 12:52:45 PM »
Richmond2000
UK / 220V land "low wattage" HPS/SON has 100V arc drop and USA/120V land bulbs have 55Volt arc drop
I am not sure the specs on a MP70 bulb but do KNOW 120V and 220V country HPS lamps are NOT the interchangeable up to around 150 watt size
« Reply #3 on: October 12, 2023, 01:18:30 PM »
Author: Mandolin Girl
That's why we have a US spec inverter to run the lower wattage of lampses below 175W, and the US ballasts to run then on.
© 2005-2024 Lighting-Gallery.net
