Author Topic: Electronic Ballast for 2x 13W GX23 lamps  (Read 3041 times)
Maxim
Filament LEDs. Both a blessing and a curse.
Electronic Ballast for 2x 13W GX23 lamps « on: August 31, 2023, 11:26:55 PM » Author: Maxim
I have an old Verilux desk lamp whose ballast and lamp have died. I would like to "retrofit" it with 2x 13W GX23 base lamps. To do so, what ballast would I need, and how would I go about wiring it?
First time messing with fluorescent ballasts and such. Thanks!
The Westinghouse Lifeguard Disease, it's here. All ye, proceed with caution.
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #1 on: September 09, 2023, 03:46:27 PM » Author: WorldwideHIDCollectorUSA
Since most GX23 base 2 pin PL13 CFL lamps have an internal starter, you will probably need to use a magnetic preheat CFL series choke ballast for these lamps. Since the magnetic preheat CFL series choke ballasts are more common, you will probably need to make a remote ballast box for this desk lamp because electronic ballasts are usually smaller than magnetic ballasts.
Maxim
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #2 on: September 09, 2023, 04:22:17 PM » Author: Maxim
Thanks! Do you have any links/suggested items to purchase?
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #3 on: September 09, 2023, 04:24:45 PM » Author: WorldwideHIDCollectorUSA
This Advance ballast should be able to drive GX23 PL13 CFL lamps pretty well:
https://www.ebay.com/itm/256142905552
Maxim
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #4 on: September 09, 2023, 04:31:25 PM » Author: Maxim
Alright; so how would I wire each individual lamp holder? Presuming neutral wire to one end and phase(?) to the other end? And, to remotely ballast this, would I need to create another container, preferably attached to the desk lamp?
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #5 on: September 09, 2023, 04:37:18 PM » Author: WorldwideHIDCollectorUSA
You would probably need a container for these ballasts, but to wire these ballasts to the lampholder, you will only need to wire the ballast and lampholder in series with each other.
Maxim
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #6 on: September 15, 2023, 08:50:42 PM » Author: Maxim
So, the came in this evening. It only has two black cables... how do I go about connecting it to the power source, the switch, and the lamp holders? Thanks so much!
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #7 on: September 15, 2023, 08:51:55 PM » Author: WorldwideHIDCollectorUSA
how many lampholders in the fixture?
Maxim
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #8 on: September 15, 2023, 08:58:59 PM » Author: Maxim
Two, both GX23 base.
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #9 on: September 15, 2023, 08:59:34 PM » Author: WorldwideHIDCollectorUSA
In this case, you actually need a second ballast.
Here is a link to a second identical ballast:
https://www.ebay.com/itm/334836555779
« Last Edit: September 15, 2023, 09:02:25 PM by WorldwideHIDCollectorUSA » Logged
Maxim
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #10 on: September 15, 2023, 09:01:34 PM » Author: Maxim
Noooooo....
So, how would I at least connect one lampholder for the time being? I'm used to ballasts having like 600000000000 wires each going to their respective place. Only two here...
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #11 on: September 15, 2023, 09:05:40 PM » Author: WorldwideHIDCollectorUSA
By the looks of it, it seems that one blue wire leads to the live output of one of the lampholders. Try connecting one ballast wire to one blue wire, the other ballast wire to the cord’s live wire, and then connecting one of the black wires opposite the blue wires to the cord’s neutral wire. If the lamp does not light, try disconnecting the previously connected blue wire from the ballast and try the other blue wire.
Try this out and let me know if it runs a conventional PL13 CFL lamp.
In addition, can I get a full view of the fixture with the lampholders and ballast chamber visible?
For the ballasts that I recommended, here is a rough sketch of the wiring diagram:
120V————-—switch————ballast 1—————lamp 1———|
                                          |—-ballast 2—————lamp 2——|  |
N——————————————————————————————|-|
« Last Edit: September 15, 2023, 09:21:14 PM by WorldwideHIDCollectorUSA » Logged
Maxim
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #12 on: September 15, 2023, 09:24:50 PM » Author: Maxim
Trying the above steps now...
Maxim
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #13 on: September 15, 2023, 09:25:49 PM » Author: Maxim
Here you go
Re: Electronic Ballast for 2x 13W GX23 lamps « Reply #14 on: September 15, 2023, 09:26:30 PM » Author: WorldwideHIDCollectorUSA
I am not done with the wiring diagram yet. I will resend it once it is done since the original diagram was messed up.
