Author Topic: Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts  (Read 1540 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts « on: August 31, 2023, 06:41:23 PM » Author: HIDLad001
Preferably in warm white color temperatures to put into incandescent fixtures.
« Last Edit: September 02, 2023, 04:39:36 AM by HIDLad001 » Logged
BT25
Re: Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts « Reply #1 on: August 31, 2023, 07:56:53 PM » Author: BT25
Do an eBay search for Philips Master-Color MHC50/U/3K.
Re: Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts « Reply #2 on: August 31, 2023, 08:45:33 PM » Author: WorldwideHIDCollectorUSA
Most low wattage ceramic metal halide lamps can safely be used on same wattage quartz metal halide ballasts, but there are certain types that are only compatible with dedicated electronic ballasts.
HIDLad001
Re: Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts « Reply #3 on: September 01, 2023, 09:02:50 AM » Author: HIDLad001
Do CMH lamps like to explode? For an open fixture, would I need an open-rated lamp or a shield?
LightsoftheWest
SRP for life.
streetlightian
Re: Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts « Reply #4 on: September 01, 2023, 05:04:44 PM » Author: LightsoftheWest
I don't think CMH lamps are prone to explosion, as the arc tube is made out of PCA - the same material used for a HPS arc tube. Regular PSMH lamps' arc tubes are made of quartz glass, which is prone to explosion.
« Last Edit: September 02, 2023, 01:17:03 AM by LightsoftheWest » Logged
LG's #1 North American light fixture identifier
HIDLad001
Re: Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts « Reply #5 on: September 02, 2023, 04:42:14 AM » Author: HIDLad001
I still decided to play it safe, and since protected lamps are readily available, I picked up a pair of Philips MHC70/C/U/MP/3K protected 70w lamps on eBay for $23.
Re: Wanted: Affordable low-wattage ceramic metal halide lamps and ballasts « Reply #6 on: September 02, 2023, 02:14:22 PM » Author: WorldwideHIDCollectorUSA
If you still want unprotected lamps, you can always use them in a proper enclosed fixture.
