Author Topic: Which halides are used in the Philips CosmoWhite CPO-TW lamps?  (Read 3510 times)
Which halides are used in the Philips CosmoWhite CPO-TW lamps? « on: May 28, 2010, 08:29:13 AM » Author: dor123
These CMH lamps are used for street lighting and have efficiency of 118 lm/w for the 140W top wattage lamp which is higher then a regular HPS lamp of 150W. They uses PGZ12 two pin base instead of the E27 or E40 base. I don't know which halides are used in these lamps (But i know that they contains sodium iodide).
Re: Which halides are used in the Philips CosmoWhite CPO-TW lamps? « Reply #1 on: June 09, 2010, 12:17:41 PM » Author: dor123
Why anyone don't answers me?
Re: Which halides are used in the Philips CosmoWhite CPO-TW lamps? « Reply #2 on: July 02, 2010, 05:08:55 PM » Author: James
This class of lamp is typically based on Cerium iodide fillings, together with sodium to control the colour point.  Cerium has not been widely used previously in other lamp types.  This chemistry when combined with the xenon filled arc tube of special dimensions to minimise thermal losses is what results in the remarkably high luminous efficacy.
Apologies for the delay in replying but I don't check this forum so often - however you can always mail me direct if you can't wait for a reply!
Best regards,
James.
Re: Which halides are used in the Philips CosmoWhite CPO-TW lamps? « Reply #3 on: July 03, 2010, 02:49:54 AM » Author: dor123
James: this chimestry is similar to the US Philips HPS Retrowhite CHM lamp. But the US HPS retrowhite gives higher CRI then the European CPO-TW. Why?
Re: Which halides are used in the Philips CosmoWhite CPO-TW lamps? « Reply #4 on: July 04, 2010, 01:14:02 AM » Author: James
I haven't analysed the chemistry in the American version so I shall take your word for it!  However I did believe previously that the US version also had additional dysprosium iodide which is responsible for more continuum radiation and a better CRI.  The increased continuum extends into the infrared where some energy is wasted, hence the lower lamp efficacies of the American version despite their much higher wattage ratings.
Re: Which halides are used in the Philips CosmoWhite CPO-TW lamps? « Reply #5 on: October 04, 2010, 01:21:22 AM » Author: dor123
James, someone in GoL told me that the arctubes of the CosmoWhite CHM lamps aren't filled with xenon, but just argon.
« Last Edit: October 06, 2010, 10:55:50 AM by dor123 » Logged
Kev
Re: Which halides are used in the Philips CosmoWhite CPO-TW lamps? « Reply #6 on: October 08, 2010, 06:09:38 PM » Author: Kev
The 60W CPO works well on 70w MH gear  ;)
