Author Topic: Broke a vintage lamp...  (Read 996 times)
Maxim
Filament LEDs. Both a blessing and a curse.
Broke a vintage lamp... « on: August 30, 2023, 01:49:10 PM » Author: Maxim
Broke my 1994 vintage Abco Smart Four-Level 100W lamp. Was unscrewing from a socket when the base came loose. Couldn't do anything about it, so I tried moving the lamp with the socket. Burst the tube that seals the gases inside. Really angry with myself. Any advice? I chucked the cracked, bent base (kept the tiny Beacon "computer" for memory) and so far still have the glass. What the ship to do? ??? :( :-\
The Westinghouse Lifeguard Disease, it's here. All ye, proceed with caution.
Re: Broke a vintage lamp... « Reply #1 on: August 30, 2023, 03:16:22 PM » Author: rjluna2
Oh dear :(
Re: Broke a vintage lamp... « Reply #2 on: August 30, 2023, 03:36:33 PM » Author: RRK
Sorry to say, but once you broke the tubulation, the lamp is pretty much FUBAR, as they say in the army... You can easily attach the base back by a drop of epoxy, but strictly a display specimen from now :(
« Last Edit: August 30, 2023, 03:38:46 PM by RRK » Logged
Re: Broke a vintage lamp... « Reply #3 on: August 30, 2023, 04:05:42 PM » Author: RRK
I would try to save that dimmer gizmo from the base and attempt to re-use it with another 100W glass...
Re: Broke a vintage lamp... « Reply #4 on: August 30, 2023, 06:30:07 PM » Author: joseph_125
Maybe you can refit the dimmer PCB from it into either another lamp, or as a remotely mounted inline device.
I've repaired lamps before with loose bases and short lead wires but once the glass breaks, you can't really do much about it.
Maxim
Re: Broke a vintage lamp... « Reply #5 on: August 30, 2023, 07:09:45 PM » Author: Maxim
"Maybe you can refit the dimmer PCB from it into either another lamp, or as a remotely mounted inline device."
Hmm, how would I go about doing so? I have plenty of 100W incandescent lamps in my possession...
Re: Broke a vintage lamp... « Reply #6 on: August 31, 2023, 12:38:31 AM » Author: RyanF40T12
ABCOs were cheapies back then so not a surprise.  toss it and be glad its gone.
Re: Broke a vintage lamp... « Reply #7 on: August 31, 2023, 12:57:24 AM » Author: RRK
You need to carefully disassemble the base and remove/desolder the electronic board or integrated circuit that did the dimmer function. Carefully cutting the metal with a dremel disc helps sometimes. Note how the connections were made. By the way,teardown pictures are very welcome!
