Author Topic: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast?  (Read 986 times)
Lamp_o_watcher
We are the Sultans... We are the Sultans Of Swing!
Nido's Hardwar3 @Lamp_o_watcher
Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « on: August 08, 2023, 05:47:17 AM » Author: Lamp_o_watcher
I have a GE 40/50DX that I wanna power up but I dont have the ballast to do so. Is it possible to use a 40w Fluoro ballast to do so? I wouldnt mind damagine the ballast but the bulb getting damaged is not an option
You are young and life is long, and there is time to kill today
And then one day you find ten years have got behind you
No one told you when to run, you missed the starting gun
Rich, Coaster junkie!
Re: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « Reply #1 on: August 08, 2023, 01:50:13 PM » Author: AngryHorse
It would certainly start and run it, but it would be slightly under run on current, and slightly high on arc voltage.
This choke delivers 0.44A @ 104 V for 36 watt fluorescent…
The mercury lamp is 0.61A @  95 V for 50 watt (specs from Philips lighting catalogue 1994).
What makes the lamp 40/50 watts? and not just 50?
« Last Edit: August 08, 2023, 01:55:58 PM by AngryHorse » Logged
Current: UK 230V, 50Hz
Power provider: e.on energy
Welcome to OBLIVION
Re: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « Reply #2 on: August 09, 2023, 12:31:20 AM » Author: Medved
What makes the lamp "40/50W"? Formally rating it for operation at the smaller current.
The 95V arc voltage corresponds more to the F36T8, suggesting it will operate the lamp at about that 36W, which should be perfectly fine for a 40W rated MV.
Re: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « Reply #3 on: August 09, 2023, 01:27:54 AM » Author: dor123
It is common for the American 50W MV lamps to be rated at both 40W and 50W. I don't know why they doing this?
Re: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « Reply #4 on: August 09, 2023, 03:01:29 AM » Author: Medved
@dor123: Probably serve the market for both of those lower power MV's, sharing common lamp product, when the market size for mainly the "40W" is rather small.
Re: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « Reply #5 on: August 09, 2023, 05:41:31 PM » Author: James
Originally Sylvania and Westinghouse only offered a 40W lamp in USA.  Then in 1969 GE introduced the 50W rating which was more aligned to the already existing 50W mercury lamps in other countries.  By the early 1970s Sylvania had copied it and also offered a 50W in USA, alongside its 40W.  GE then copied Sylvania's 40W and offered both types.  For a few years both manufacturers produced their own 40W and 50W types in USA.  Due to the very small difference, it was found possible to make a dual rated lamp that operated equally well at both 40W and 50W, the actual power depending on the ballast used.  That resulted in the curious introduction of the unique American 40/50W mercury lamp.  I think that happened sometime around 1973-1975.
Re: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « Reply #6 on: September 25, 2023, 02:57:44 AM » Author: WorldwideHIDCollectorUSA
As far as I know, Japan apparently has some 40W mercury vapor lamps that might be electrically identical to the North American 40W H45 mercury vapor lamps.
Re: Is it possible to use a 40/50w Mercury Vapor bulb on a 40w Fluorescent ballast? « Reply #7 on: September 25, 2023, 03:09:37 AM » Author: WorldwideHIDCollectorUSA
@AngryHorse, I believe that the 40W H45 mercury vapor lamps and Japanese 40W mercury vapor lamps were rated for an even lower current at around 0.53A, but their arc voltage drop might be somewhere around 85V, but I am not entirely sure. Even with these parameters in mind, a 4 foot 40W T12 fluorescent tube ballast will still underdrive those 40W mercury vapor lamps as well.
