Author Topic: Wanted: European HPL (not HPL-N) mercury lamps and heat resistant purple lacquer  (Read 1370 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
Wanted: European HPL (not HPL-N) mercury lamps and heat resistant purple lacquer « on: July 31, 2023, 07:16:35 AM » Author: HIDLad001
I think you know what I want to make.  8;)
RadiantMV
Re: Wanted: European HPL (not HPL-N) mercury lamps and heat resistant purple lacquer « Reply #1 on: July 31, 2023, 09:59:22 AM » Author: RadiantMV
North American /C lamps are just as rare as the European HPLs so if you’re planning to make an /X those would work just as well.
Also Radium in Germany made actual /X bulbs, apparently up to 2000 watts  :poof:
HIDLad001
Re: Wanted: European HPL (not HPL-N) mercury lamps and heat resistant purple lacquer « Reply #2 on: July 31, 2023, 10:09:59 AM » Author: HIDLad001
I thought that they would be more common. I guess North American ones would be better suited to the task because I wouldn't have to import them from halfway across the world and find control gear to run them on.
:poof:
Re: Wanted: European HPL (not HPL-N) mercury lamps and heat resistant purple lacquer « Reply #3 on: August 01, 2023, 04:42:15 AM » Author: WorldwideHIDCollectorUSA
An important fact to know about foreign mercury vapor lamps in general is that almost all 250w and 400w mercury vapor lamps are electrically interchangeable with each other across the same wattage no matter where they are marketed to.
