January 02, 2025, 10:44:12 PM
Modern
Atlanta Motor Speedway Floodlights
Topic: Atlanta Motor Speedway Floodlights (Read 1105 times)
« on: July 09, 2023, 10:56:47 AM »
Yesterday there was a segment about the
lighting system from
WSB-TV
news. The reporter showed us the big 1500 Watts MH BT-56 bulb with arc tube in 45 degree angle with matte black dome. Has anyone seen such specimen in the wild?
Re: Atlanta Motor Speedway Floodlights
« Reply #1 on: July 09, 2023, 02:35:31 PM »
https://www.wsbtv.com/news/local/henry-county/nascar-returns-atlanta-motor-speedway-under-lights/2OOFMQJNRNAFVLN7KWKXYALIHU/
I've never seen them like that before. I'd assume it's to help cut the glare ? I used to go to the spring race at AMS for close to 20 years . I quit going when they moved the date to latter in the season .
« Reply #2 on: July 09, 2023, 10:10:57 PM »
The closest I've seen are
these
which were located in a park but were also built by Musco. Interestingly the lamps are slightly different too in regards to the shape and location of the black paint on the lamp.
I suppose the base luminaire for these is pretty customizable and are build to order. In my example, a few had the external glare control baffle and one has different reflector inserts. Finally one has fully clear lamp, although that might have been a spot replacement.
« Reply #3 on: July 09, 2023, 10:15:32 PM »
I did notice that the ones in the video I linked don't look to have the entire top coated . I wonder if they custom make the lamps specifically for different applications ?
I've seen ones like in your link at a local go cart track .
« Reply #4 on: July 09, 2023, 11:39:40 PM »
I wonder too, and how many variations of those Z framed MH lamps existed.
Unfortunately it seems like all the details on the MH systems had been purged from Musco's website.
Last Edit: July 10, 2023, 12:03:11 AM by joseph_125
« Reply #5 on: July 09, 2023, 11:44:38 PM »
I wonder where the speedway gets their lamps , ballasts , etc. ??
« Reply #6 on: July 10, 2023, 12:28:27 AM »
Apparently Musco sells replacement parts directly and also service agreements. I suppose there might also be non OEM lamps. Ballasts you can probably just use any core and coil kit IMO.
https://www.musco.com/replacement-parts/
« Reply #7 on: July 10, 2023, 12:35:17 AM »
Makes sense !
« Reply #8 on: July 10, 2023, 10:46:02 AM »
Thanks for the video link, wide-lite 1000
Joe, looks like half coated matte black on the top of the bulb
Also, thanks for the light fixture link here as well, Joe
I can see that it has the same light bulb as shown at the video presentation as well.
« Reply #9 on: July 10, 2023, 07:34:59 PM »
No problem !
