Author Topic: 4000k 50w Sylvania Metalarc Pro-Tech... do they exist?  (Read 11755 times)
Re: 4000k 50w Sylvania Metalarc Pro-Tech... do they exist? « Reply #15 on: July 10, 2023, 12:46:24 PM » Author: joseph_125
I recall mine were 3000K when I tested them but I can probably pull one out for testing later to confirm this. Perhaps Venture might have what you're looking for in 4000K. They had a lot of rather unique MH lamps including those long life dual arctube lamps.
Ahh, the 1980s GE HID sleeve effect :lol:, I'm not sure why GE actually made those sleeves in the 80s that listed all the HID types on it. Fortunately the 90s sleeves when back to listing only the correct source on it.
The "seller refurbished" on lamps is always funny too, how to do even refurbish a lamp.  ???
BT25
Re: 4000k 50w Sylvania Metalarc Pro-Tech... do they exist? « Reply #16 on: July 11, 2023, 11:29:54 AM » Author: BT25
If these are being installed in an enclosed fixture, why not use Philips MHC50/U/4K lamps? These are compatible with the ANSI M110 specs, even though they are referred as a C110.
« Last Edit: July 11, 2023, 07:11:39 PM by BT25 » Logged
Re: 4000k 50w Sylvania Metalarc Pro-Tech... do they exist? « Reply #17 on: July 11, 2023, 06:26:54 PM » Author: wide-lite 1000
 Eric :  MHC 100's will run on a 50w M110 ballast ?
BT25
Re: 4000k 50w Sylvania Metalarc Pro-Tech... do they exist? « Reply #18 on: July 11, 2023, 07:11:00 PM » Author: BT25
Oops...I meant MHC50/U/4K... :lol: :-[
Re: 4000k 50w Sylvania Metalarc Pro-Tech... do they exist? « Reply #19 on: July 11, 2023, 07:18:32 PM » Author: wide-lite 1000
 Figured !!  :mrg:
