Author Topic: Re-installing fluorescents after a LED conversion  (Read 4326 times)
arcblue
Re-installing fluorescents after a LED conversion « on: May 08, 2023, 03:25:57 PM » Author: arcblue
So this is what happens when ballasts are removed for a LED conversion but then someone installs fluorescents back into the fixture, not knowing the ballast is no longer there: https://www.youtube.com/watch?v=hTleg8upX6k
I'm lampin...
Re: Re-installing fluorescents after a LED conversion « Reply #1 on: May 08, 2023, 03:27:30 PM » Author: WorldwideHIDCollectorUSA
I actually posted this video a while back here on LG.
Here is my thread about this same video:
https://www.lighting-gallery.net/index.php?topic=9701.0
« Last Edit: May 08, 2023, 03:31:18 PM by WorldwideHIDCollectorUSA » Logged
Re: Re-installing fluorescents after a LED conversion « Reply #2 on: May 09, 2023, 07:40:43 PM » Author: joseph_125
I guess these are the tubes that are wired to the line on only one end. I have some that use both ends with shunted hot to one end and shunted neutral to the other end. Those might give rather interesting results if someone stuck a fluorescent in them. Especially on a 240v system and with a 2ft or shorter tube.
