Author Topic: Found The Correct Leak Transformer For A Thorn 200W SLI/H HO  (Read 1347 times)
Bush DAC90A
What Goes Up Must Come Down
Found The Correct Leak Transformer For A Thorn 200W SLI/H HO « on: May 03, 2023, 04:25:37 PM » Author: Bush DAC90A
Hi as per title I am very happy as the the leak transformer is the correct one for my lamp it is a BLI instant start AME 531-H it dates from pre 1960 as the currant rating is C/S as HZ was 1960 onwards . The Leak transformer runs cool and quiet as there must be no shortened turns on the windings or loose laminations kind regards Bob ;D
Re: Found The Correct Leak Transformer For A Thorn 200W SLI/H HO « Reply #1 on: May 08, 2023, 05:03:42 PM » Author: WorldwideHIDCollectorUSA
I am so happy that you found the correct ballast for these interesting low pressure sodium lamps. You did well to find it.
Re: Found The Correct Leak Transformer For A Thorn 200W SLI/H HO « Reply #2 on: May 09, 2023, 07:38:45 AM » Author: Rommie
Saw one on eBay a little while ago but was outbid, wonder if it was you that beat me  :wndr:
If it was, that's ok, it's how it goes, I'll get one eventually  8) :sli:
