Author Topic: 175 watt MV Cap  (Read 1100 times)
GE PM
Ge Post Mount
175 watt MV Cap « on: April 22, 2023, 06:59:50 PM » Author: GE PM
I have a 277-volt fixture that GE put a multi-volt ballast. will I have to change the cap in line with the socket to make it work properly, or can I leave it how it is? Merc reg.
Collector of all things GE! Except for LEDs.
Utility Company: SCE
Re: 175 watt MV Cap « Reply #1 on: April 22, 2023, 07:01:55 PM » Author: WorldwideHIDCollectorUSA
Can’t really understand what you are trying to do. Are you looking at the idea of replacing the 277v ballast with a multi volt ballast?
Re: 175 watt MV Cap « Reply #2 on: April 22, 2023, 08:02:47 PM » Author: joseph_125
So my understanding is that you want to run a 277v multi volt fixture on 120v correct?
That's really easy on modern GEs, all you need to do is to change the Faston connector on the ballast primary from the "277v" position to the "120v" position. On modern OEM GE gear, it's typically a blue plastic Faston connector. No need to replace the capacitor in line with the socket.
BT25
The Six Shades of Mercury Vapor
Re: 175 watt MV Cap « Reply #3 on: April 22, 2023, 11:34:43 PM » Author: BT25
What Joseph_125 said is correct...you shouldn't have any problems.
