January 10, 2025, 07:14:38 AM
Modern
Cleaning a SOX Lamp
Topic: Cleaning a SOX Lamp (Read 1064 times)
Econolite03
Matthew E.
Cleaning a SOX Lamp
« on: April 20, 2023, 08:42:01 PM »
Econolite03
(Disclaimer: I have no idea if this is the right section to post this thread, so mods feel free to move it.)
I have a Philips SOX lamp, and unfortunately the lamp has some sort of residue on the outer glass from being in storage. It looks like something that could be cleaned easily with rag with water but I don't want to risk doing any damage to the lamp. Any ideas (preferably from experience) that I could use to clean the lamp safely is welcomed.
Thanks.
Re: Cleaning a SOX Lamp
« Reply #1 on: April 20, 2023, 08:52:25 PM »
I typically just use windex . (BE VERY CAREFUL AROUND THE ETCH !!!)
Econolite03
Matthew E.
« Reply #2 on: April 20, 2023, 08:53:35 PM »
Econolite03
I was thinking exactly that. How well does it work?
« Reply #3 on: April 20, 2023, 08:57:09 PM »
It will usually remove most contaminents from the glass (I have also wiped off an etch or 2 !) I've also used 0000 steel wool to remove heavier contaminents but I don't know if that will damage any coatings on a SOX lamp .
Econolite03
Matthew E.
« Reply #4 on: April 20, 2023, 08:58:45 PM »
Econolite03
10-4.
« Reply #5 on: April 20, 2023, 10:59:49 PM »
On more delicate lamps, I start with a slightly damp paper towel. If that doesn't work, I get some 70% isopropyl alcohol from the pharmacy, put that on a paper towel and wipe the lamp off with that.
Be careful around the etch, or avoid it if it's not too dirty.
Econolite03
Matthew E.
« Reply #6 on: April 21, 2023, 01:37:17 AM »
Econolite03
Ahh, I see.
So here’s what I ended up doing, I took a rag with a little bit of water and it cleaned the lamp perfectly. I did avoid the etch so that’s fine.
Michael
« Reply #7 on: April 21, 2023, 09:00:16 AM »
Michael
Just avoid cleaning the bulb on the inside as there the reflective coating resides.
The outside surface may be cleaned like a normal bulb or fluorescent tube ex. the etch.
