yeah being more detailed and actually listing them is good.....
For me....
GE M-250 (April 1970, MV) - does not have orignal ballast since it got burnt out
Cooper OVH (2004, MH) It originally had 250 watt HPS ballast that never worked...became a 175 watt MV, now installed a pulse start MH 100 watt
GE NEMA (HPS) had a MV but burnt out, got it with new MV ballast...I installed HPS)
GE M-100 (1963, MV) - everything is original for that fixture
Westinghouse Silverliner OV-15 (1968, MV) - All is original except for the refractor
Westinghouse Silverliner OV-14B (1957, MV) - has no ballast for now......
Older GE mercury vapor NEMA (1964 with a older LM gumball set refractor, MV) - everything is original for the NEMA part
McGraw Edision Unidor 175 (1976, HPS) - Everything is original for this fixture except refractor
Philips XGS103 (1986, LPS) the only fixture that accepts European power since it came from the Netherlands....Its now powered with a step up transformer......
Others that are not pictured in the Lighting Gallery is:
-Old AE 13..(the older curvier version) (1962, has a burnt out MV ballast)
-Cooper UTR TRADITIONAIRE post top (1993, HPS)
-Westinghouse Silverliner OV-12 (1962, MV) all original parts
(by the way you can find the Old AE and the OV-12 in my webpage
here )
That means I have 12 streetlight fixtures.....
I used to have a Westinghouse OV-20 which got busted but I still have parts of it....it was my first streetlight....
Don't forget, I also have a 1985 Crouse Hinds traffic light....
