Author Topic: Lamp data of US discharge lamps  (Read 6299 times)
Lamp data of US discharge lamps « on: January 26, 2023, 10:33:53 AM » Author: Alex
Hello,
is there a complete table of the electrical caractheristics of lamps run of ballast were an ANSI code (i.e. S52 for a HV 1kW HPS lamp) exists?
Best regards,
Re: Lamp data of US discharge lamps « Reply #1 on: January 30, 2023, 03:39:12 PM » Author: James
I’m not sure a table has been published, but in the ANSI standards there are datasheets for each lamp type which include this information.
Re: Lamp data of US discharge lamps « Reply #2 on: January 30, 2023, 03:51:13 PM » Author: Alex
Hello James,
Thank you. If I find time ill dig it out and will put a table together and publisch here.
Best regards,
Re: Lamp data of US discharge lamps « Reply #3 on: January 24, 2024, 12:11:41 AM » Author: WorldwideHIDCollectorUSA
This was the information that I have gathered so far. Some information may not be correct.
See here:
https://www.lighting-gallery.net/index.php?topic=117.0
Re: Lamp data of US discharge lamps « Reply #4 on: January 25, 2024, 12:41:10 PM » Author: RRK
That useful compilation of ANSI spec by WorldwideHIDCollectorUSA deserves a permalink on the L-G front page!
Some info at the end of this old article, too
http://reefkeeping.com/issues/2007-03/sj/index.php
Re: Lamp data of US discharge lamps « Reply #5 on: January 27, 2024, 01:07:37 PM » Author: WorldwideHIDCollectorUSA
Here is the updated list of North American HID lamp arc voltage drops and operating currents:
Medium/High Pressure Mercury Vapor
40w    – H45 90V 0.53A
50w    – H46 96V 0.6A
75w    – H43 130V 0.66A
80w         – H95 115V 0.8A
100w    – H38/H44/H4 130V 0.85A
125w       – H42 125V 1.15A
175w    – H39/H22 130V 1.5A
250w    – H37/H5 130V 2.1A
400w    – H33/H25/H1 135V 3.2A
425w       – H40/H17 265V 1.7A
700w    – H35/H18 265V 2.8A
1000w    – H34/H12 135V 8.0A
1000w    – H36/H15 265V 4.0A
Metal Halide (Red's Probe Start, Rest's Pulse Start)
20w    – M156 94V 0.215A
22w    – M175 100V 0.22A
35/39w    – M130 85V 0.53A
50w    – M110/M148 85V 0.66A
70w    – M98/M143/M139 90V 0.88A
100w    – M90/M140 100V 1.2A
125w    – M150 125V 1.15A
150w    – M102/M142 100V 1.8A
175w    – M57 (M107 for 150w energy saving lamps) 130V 1.5A
175w    – M137/M152 130V 1.5A
200w    – M136 130V 1.6A
250w    – M58 130V 2.1A
250w    – M138/M153 130V 2.1A
300w.       – M151 130V 2.5A
320w    – M132/M154 135V 2.6A
350w    – M131 135V 2.8A
400w    – M59 (M165 for 360w energy saving lamps) 135V 3.2A
400w    – M135/M155 135V 3.2A
450w    – M144 135V 4.0A
750w    – M149 200V 4.0A
875w    – M166 ???
1000w    – M47 265V 4.0A
1000w    – M141 265V 4.0A
1500w    – M48 265V 6.2A
1650w    – M112 270V 6.6A
2000w     – M134 265V 9.2A
Double Ended Metal Halide
70w    – M85 90V 1.0A
100w    – M91 100V 1.2A
150w    – M81 100V 1.8A
250w    – M80 100V 3.0A
1500w    – M133 ???
Low Pressure Sodium Vapor (SOX only)
18w    – L69 57V 0.35A
35w    – L70 70V 0.6A
55w    – L71 100V 0.6A
90w    – L72 112V 0.95A
135w    – L73 165V 0.95A
180w    – L74 245V 0.95A
High Pressure Sodium Vapor
35w    – S76 52V 0.83A
50w    – S68 52V 1.18A
70w    – S62 52V 1.6A
100w    – S54 55V 2.1A
150w    – S55 55V 3.2A
150w    – S56 100V 1.8A
200w    – S66 100V 2.4A
250w    – S50 100V 3.0A
310w    – S67 100V 3.6A
400w    – S51 100V 4.5A
430w    – S145 100V ??A
600w    – S106 110V 6.2A
750w    – S111 120V 7.0A
1000w    – S52 250V 4.7A
