Author Topic: Purple flashes during MV warmup?  (Read 1159 times)
RCM442
Purple flashes during MV warmup? « on: October 30, 2022, 02:26:40 PM » Author: RCM442
One of my 175 watt lifeguard MV lamps has a bunch of purple flares when it's warming up. Normal?
Administrator #4
Econolite03
Matthew E.
Re: Purple flashes during MV warmup? « Reply #1 on: October 30, 2022, 03:55:21 PM » Author: Econolite03
It should be fine, one of my Norelco DXs did that but works as usual otherwise.
Re: Purple flashes during MV warmup? « Reply #2 on: October 30, 2022, 11:37:43 PM » Author: wide-lite 1000
I've seen that a lot as most of the MV lamp I run are clear . No idea what causes it though .
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
Re: Purple flashes during MV warmup? « Reply #3 on: November 20, 2022, 06:46:47 PM » Author: 108CAM
I think the purple flash may be the electrical arc inside the tube. Many of my MV lamps do it just after being turned on but before they turn pink when the mercury begins to vaporise.
1925-2002
Bring back the AJF Zodiacs!
bulb_tester2009
回复:MV预热期间紫色闪烁? « Reply #4 on: November 29, 2022, 07:44:37 PM » Author: bulb_tester2009
The problem is that normally, MV lights using phosphors should start with pink flares instead of purple, which is very magical. Because my Philips and Osram MV lights start with pink flares.
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
