Author Topic: Fixing cloudy glass  (Read 2427 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
Fixing cloudy glass « on: September 12, 2022, 09:07:11 AM » Author: HIDLad001
I wanted to remove the frosting from my GE A19 CFL, so I used a razor blade to remove it. It worked, but certain parts of the glass were cloudy by the time I was done, I guess the razor blade made it cloudy, but I am not sure. Do any of you know a method to remove the cloudiness and make the glass bulb crystal clear?
Re: Fixing cloudy glass « Reply #1 on: September 12, 2022, 10:07:49 AM » Author: Mandolin Girl
Not sure how to fix that, but we had success in using isopropyl alcohol in removing the coating.  :wndr:
HIDLad001
Re: Fixing cloudy glass « Reply #2 on: September 12, 2022, 10:15:50 AM » Author: HIDLad001
I tried using isopropyl alcohol, but it didn't work. I ended up using a razor blade, and now the glass is cloudy.
Re: Fixing cloudy glass « Reply #3 on: September 12, 2022, 10:19:05 AM » Author: Mandolin Girl
The cloudiness might be minute scratches then.  :wndr:
HIDLad001
Re: Fixing cloudy glass « Reply #4 on: September 12, 2022, 10:21:45 AM » Author: HIDLad001
Do you think you could fix it with a polish?
Re: Fixing cloudy glass « Reply #5 on: September 12, 2022, 10:28:56 AM » Author: Mandolin Girl
Possibly, do an online search for polishing compounds, they might work.
HIDLad001
Re: Fixing cloudy glass « Reply #6 on: September 12, 2022, 10:33:40 AM » Author: HIDLad001
Would WD-40 And high grit sandpaper work? I have seen people using it to remove scratches and clouding from plastic.
Re: Fixing cloudy glass « Reply #7 on: September 12, 2022, 10:35:17 AM » Author: Mandolin Girl
Possibly, but just remember that the lamp will become very slippery so keep a good grip on it.
HIDLad001
Re: Fixing cloudy glass « Reply #8 on: September 12, 2022, 10:36:14 AM » Author: HIDLad001
I would probably screw it into a socket that isn't plugged into anything to hold it for me.
Re: Fixing cloudy glass « Reply #9 on: September 12, 2022, 10:37:29 AM » Author: Mandolin Girl
That would work.
HIDLad001
Re: Fixing cloudy glass « Reply #10 on: September 12, 2022, 10:38:46 AM » Author: HIDLad001
We already have WD-40, and high-grit sandpaper is cheap.
Re: Fixing cloudy glass « Reply #11 on: September 12, 2022, 11:47:53 AM » Author: Mandolin Girl
Go for it, but get as high a grit count as you can.  :wndr:
HIDLad001
Re: Fixing cloudy glass « Reply #12 on: September 12, 2022, 12:08:17 PM » Author: HIDLad001
Such high-grit sandpaper will have other uses for me besides fixing this light bulb. I might use it to fix a scratched screen on a CRT television, or removing scratches from plastics.
Re: Fixing cloudy glass « Reply #13 on: September 12, 2022, 12:10:13 PM » Author: Mandolin Girl
Absolutely, it's always better when you can use things for multiple things.  :love:
HIDLad001
Re: Fixing cloudy glass « Reply #14 on: September 12, 2022, 12:10:42 PM » Author: HIDLad001
Very true.
