Author Topic: 4W T5 insect zapper on a capacitive dropper ballast with a glow starter  (Read 2972 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
4W T5 insect zapper on a capacitive dropper ballast with a glow starter « on: August 27, 2022, 04:33:29 PM » Author: HIDLad001
The lamp sometimes starts before the glow-bottle has time to switch it.
https://www.youtube.com/watch?v=uDQC7RP_l9c&t=339s
Re: 4W T5 insect zapper on a capacitive dropper ballast with a glow starter « Reply #1 on: August 30, 2022, 05:50:58 AM » Author: dor123
What is the OCV of the ballast without the glow starter? If it is 230V or more, you expected for the lamp to start directly on the ballast OCV before the glow starter firing it.
HIDLad001
Re: 4W T5 insect zapper on a capacitive dropper ballast with a glow starter « Reply #2 on: August 30, 2022, 07:37:30 AM » Author: HIDLad001
I don't know, I didn't make this video.
Re: 4W T5 insect zapper on a capacitive dropper ballast with a glow starter « Reply #3 on: September 02, 2022, 02:40:59 AM » Author: Medved
Yes, it is fed by 230V. The capacitive dropper is quite a horrible way to feed the tube, indeed, I think using a common simple CFL ballast would lead to way longer life of everything and would not be any bigger nor heavier, nor much more expensive (when using the common circular PCB ballast assembly used in pretty much all cheep CFL's)...
