Author Topic: How much time your Osram Smartlux T5 and Philips Essental T5 lasts  (Read 1003 times)
How much time your Osram Smartlux T5 and Philips Essental T5 lasts « on: August 08, 2022, 10:40:44 AM » Author: dor123
How much time your Osram Smartlux T5 and Philips Essental T5 lasts on your programmed start electronic ballasts?
The last Chinese Osram Smartlux T5 HO 54W/865 SL Chinese, lasted one year before relampping on the fixture at the low floor of my hostel and blackened very fast, and the current Chinese Philips Essential TL5 54W/865, showing slight blackening after several days only. The lamps seems to blacken during operation and not during starting, which looks exactly like the American rapid-start ballasts.
How much time your Chinese Osram and Philips T5 lamps lasts on a quality programmed start ballast?
bulb_tester2009
Re: How much time your Osram Smartlux T5 and Philips Essental T5 lasts « Reply #1 on: August 17, 2022, 02:26:02 AM » Author: bulb_tester2009
The nominal life of the Philips Essential TL5 lamp is 20,000 hours. However, according to my actual use, the two electrodes of the Philips TL5 14W/865 inside the non-preheated electronic ballast headlight in my home are significantly blackened after 1 year of use, but the brightness has not changed.
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
bulb_tester2009
Re: How much time your Osram Smartlux T5 and Philips Essental T5 lasts « Reply #2 on: August 17, 2022, 02:29:03 AM » Author: bulb_tester2009
The blackening may have been caused by the absence of a cathodic protection ring inside Philips' Chinese version of Essential.
 :hps::hps::hps:
Note:
Re: How much time your Osram Smartlux T5 and Philips Essental T5 lasts « Reply #3 on: August 17, 2022, 06:16:25 AM » Author: dor123
T5 HO and HE don't have a cathode guard usually.
