Author Topic: Fluorescent ballast for LPS  (Read 3423 times)
Xytrell
Fluorescent ballast for LPS « on: January 24, 2010, 01:48:55 PM » Author: Xytrell
I want a LPS system, but I'd rather not pay $300 for a ballast. I've heard of people using fluorescent ballasts to run LPS bulbs. How does that work and what do I need? It'd be nice to have at least 90W, but if that's not possible I can deal. Also, are there any other sources for LPS bulbs besides 1000bulbs?
Re: Fluorescent ballast for LPS « Reply #1 on: January 24, 2010, 02:49:32 PM » Author: Medved
With the ballast you have to look for operating current (it has to match, LPS is not as tolerant as fluorescent: It withstand no overcurrent at all and on undercurrent the efficacy drop and warm-up time rise significantly, so no more then 10%) and similar arc voltage.
In order to get them you have two options:
1) Find lamp/ballast combination meeting the above (so you are very limited in bulb wattage selection; look for instant start ballasts)
2) Design your own ballast for the lamp you want...
Xytrell
Re: Fluorescent ballast for LPS « Reply #2 on: January 24, 2010, 04:47:46 PM » Author: Xytrell
Eh... Google tells me LPS requires 300-700V depending on wattage. Fluorescents need more like 70-100V don't they? It doesn't look like any match up at all.
Re: Fluorescent ballast for LPS « Reply #3 on: January 24, 2010, 07:15:31 PM » Author: joseph_125
I've had success running LPS lamps on a electronic instant start ballast for T8s as most of them have a OCV of around 500-600V which should strike a LPS lamp. As for which kind of IS ballast it depends mostly on the wattage of the lamp you're planning to run.
I didn't buy anything from these stores but both prolighting and lightbulbdepot both sell LPS lamps and ballasts and I think the latter store also sells the BY22D socket for LPS lamps but all this stuff is really expensive.
Xytrell
Re: Fluorescent ballast for LPS « Reply #4 on: January 25, 2010, 12:17:51 AM » Author: Xytrell
So would something like this 96W ballast work for a 90W LPS bulb, or this 32W ballast for a 35W LPS bulb?
Re: Fluorescent ballast for LPS « Reply #5 on: January 25, 2010, 01:05:06 AM » Author: Medved
Neither of combinations would work.
SOX18 require 0.35A,
SOX35 and 55W require 0.6A,
above 0.9..0.95A.
wfile
F96T8 require ~0.5A
F32T8 about 0.36A
The closest combinations i found among US lamps are:
F96T12 (0.85A) with single SOX90W
F32T8 (0.36A) with double SOX18W in series
