Author Topic: How many things can you spot that are wrong with this?  (Read 849 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
How many things can you spot that are wrong with this? « on: July 28, 2022, 09:50:52 AM » Author: HIDLad001
https://www.youtube.com/watch?v=NFQWaB4mF7U&t=495s
Administrators, feel free to take this down or move it if it breaches forum rules.
Re: How many things can you spot that are wrong with this? « Reply #1 on: July 28, 2022, 10:50:37 PM » Author: wide-lite 1000
Wrong ballast , crappy wiring job , heat from the lamp will eventually melt the PVC pipe , An ignitor is NOT called a "sparker" !!
Econolite03
Matthew E.
Re: How many things can you spot that are wrong with this? « Reply #2 on: July 29, 2022, 03:53:03 AM » Author: Econolite03
I kinda see what he tried to do, just it wasn’t executed the right way.
Now on Linktree
Re: How many things can you spot that are wrong with this? « Reply #3 on: July 29, 2022, 09:34:44 AM » Author: Mandolin Girl
Well that's 9 minutes and 21 seconds of my life I'll never get back  ::)
Re: How many things can you spot that are wrong with this? « Reply #4 on: July 29, 2022, 09:35:08 AM » Author: Mandolin Girl
This springs to mind...
 :poof: :mrg:
HIDLad001
Re: How many things can you spot that are wrong with this? « Reply #5 on: July 29, 2022, 12:14:12 PM » Author: HIDLad001
LOL!   :lol:
Re: How many things can you spot that are wrong with this? « Reply #6 on: July 29, 2022, 11:19:48 PM » Author: wide-lite 1000
@ Sammi : I believe it's called natural selection !!
Re: How many things can you spot that are wrong with this? « Reply #7 on: July 29, 2022, 11:37:01 PM » Author: joseph_125
The most sketchy thing has to be the soldered leads on the lamp base and the PVC pipe base.  :poof: ::) A proper mogul socket is only a few bucks online.
I'm surprised that the lamp dosen't cycle too. He's using a 100w ballast which is designed for a 55v lamp while the lamp looks to be a 250w which has a 100v arctube. Perhaps it's underdriven so much that it never really warms up and hence won't cycle on a 55v ballast. The underdriving is probably the reason why it has a LPS look to it too. It's not truly monochoromatic like a LPS since there are faint emissions from other elements in the arc tube like xenon and mercury that a true LPS lamp won't have.
« Last Edit: July 29, 2022, 11:48:37 PM by joseph_125 » Logged
Re: How many things can you spot that are wrong with this? « Reply #8 on: July 29, 2022, 11:42:41 PM » Author: wide-lite 1000
The ballast is a Sylvania 100w M90 PSMH .
Re: How many things can you spot that are wrong with this? « Reply #9 on: July 29, 2022, 11:49:06 PM » Author: joseph_125
Ok that explains the lack of cycling then.
HIDLad001
Re: How many things can you spot that are wrong with this? « Reply #10 on: July 30, 2022, 08:26:14 AM » Author: HIDLad001
The lamp would probably last forever that way.
