Author Topic: Under running high pressure sodium lamps  (Read 929 times)
HIDLad001
GoL UCwvPaxz1-rbLAjLpk55zl1A
Under running high pressure sodium lamps « on: July 01, 2022, 03:03:16 PM » Author: HIDLad001
I am wondering if it is possible to under run a high pressure sodium lamp in such a way that pressure broadening doesn't occur, and it stays that beautiful monochromatic yellow like a low pressure sodium lamp  :lps:. The way I think it would be done is by starting it on a regular ballast, but when the lamp turns yellow, you disconnect it and then connect it to something like a CCFL inverter. Is this possible or am I just crazy?
Re: Under running high pressure sodium lamps « Reply #1 on: July 01, 2022, 03:53:07 PM » Author: Medved
Formally HPS use to be rated for dimming down to below 30% (some rate it down to 20%, but not sure if that is general thing) using impedance dimmers (essentially connecting an extra choke in series; speaking about European 230V territory with series chokes). That will narrow the peak a lot, but I don't think it will really make it monochromatic. Because formally rated forit, I would assume electrodes are still able to maintain sufficient temperature for emission.
Going below that means you will be risking cold electrode operation, so their damage (and the consequent arctube blackening) by sputtering.
Plus the other components (Hg,...) present in the fill will pop up in the spectrum, so even when really cold, it won't be the LPS color you are, my guess, aiming for...
HIDLad001
Re: Under running high pressure sodium lamps « Reply #2 on: July 01, 2022, 05:45:04 PM » Author: HIDLad001
Ah, I figured it wouldn't be possible.  :sadbulb:
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
Re: Under running high pressure sodium lamps « Reply #3 on: July 01, 2022, 07:45:29 PM » Author: 108CAM
Even if it was possible, the light emitted may still not be fully monochromatic due to the small amount of mercury inside the lamp. You're better off using an SOX lamp if you have one and turning off or blocking out as much unwanted light as you can so the monochrome effect isn't ruined by other light sources that have a higher CRI.
1925-2002
Bring back the AJF Zodiacs!
Re: Under running high pressure sodium lamps « Reply #4 on: July 02, 2022, 03:29:09 AM » Author: WorldwideHIDCollectorUSA
From what I am aware of, some high pressure sodium lamps have been known to last a very long time due to being underdriven after they are warmed up to full power before being dimmed down. I remember having an extensive discussion with some knowledgeable LG members about high pressure sodium lamps and mercury vapor lamps lasting longer being underdriven on a LG post, but I do not seem to find that post anywhere as of now.
Re: Under running high pressure sodium lamps « Reply #5 on: July 02, 2022, 04:23:30 AM » Author: dor123
Here in Israel, we have lots of small lanterns with 70W HPS ballasts that run 125W MV lamps. They are slightly underdriven, but still runs in hot cathodes mode.
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: Under running high pressure sodium lamps « Reply #6 on: July 02, 2022, 09:04:09 AM » Author: Foxtronix
I think it can be done with capacitors as well. Constant-wattage ballasts in North America already have one in series with the lamp, so lowering its value can do the trick. Like say replace the original one with a set of equivalent parallel, smaller value units and switch some of them in and out of circuit. Or a string of series capacitors and bypass one of them (in that case the switching action would have an opposite effect on the active capacitive reactance in the circuit). If you have basic knowledge of AC circuit analysis, it's fairly easy to figure out a way to modify the final impedance of the ballast circuitry so that it can run the lamp at more than one power level. And HPS lamps, because of how they were designed, can run at lower power. I guess their arc voltage remains the same and it's actually the current that's lower.
Now I wonder if it's possible to do that with a reactor or HX ballast as well. I assume it is.
Re: Under running high pressure sodium lamps « Reply #7 on: July 02, 2022, 11:40:13 AM » Author: WorldwideHIDCollectorUSA
To get any discharge lamp to run at a lower operating current on simple choke ballasts and HX autotransformer ballasts, you will need to lower the mains voltage by using a variac. One of our knowledgeable LG members has used the lowered mains voltage technique to operate North American 700w H35 mercury vapor lamps and North American 1500w M48 probe start metal halide lamps properly on British 220v-240v 50hz mains on HX autotransformer ballasts.
