Author Topic: Pros and Cons about MH lamps  (Read 11534 times)
TudorWhiz
Pros and Cons about MH lamps « on: November 08, 2006, 06:45:16 PM » Author: TudorWhiz
READ THIS FIRST
Here I am gonna start something fun for you......and educational so you guys can learn.....but here's the rules....
only one positive OR a negative on each post....not both Pos. and Neg., also if the post is a negative please put subject as "Negative" or if its a Positive subject it as Positive....
Also I would like each person to get chance to post something....Please don't post 2 times....instead if you are the last person to post.....wait for one other person to post...then you can post as long as there is no double post of the same person
__________________________________
Example
Post 1: Theresa
Post 2: Lucy (Theresa can't Post this)
Post 3  Polly (it is OK for Theresa to post...but Lucy can't post on this because she was the last to post but can post on 4th)
Post 4: Jamie (Theresa and Lucy either can post since the last person was Polly and Polly can't post this one)
So post only either one Pro or a Con about MH lamps....
UPDATE: another idea I had...you can set the message icon to thumbs up for Positive and thumbs down for negative
Enjoy!
« Last Edit: November 08, 2006, 08:06:48 PM by Jace the TudorMan! » Logged
mr_big
Negative « Reply #1 on: November 08, 2006, 06:51:37 PM » Author: mr_big
If they are not replaced before end of life they can and will explode
« Last Edit: November 08, 2006, 07:00:19 PM by Jace the TudorMan! » Logged
TudorWhiz
Positive « Reply #2 on: November 08, 2006, 06:55:55 PM » Author: TudorWhiz
Bright white crisp light
« Last Edit: November 08, 2006, 07:00:28 PM by Jace the TudorMan! » Logged
mr_big
Positive « Reply #3 on: November 08, 2006, 07:11:29 PM » Author: mr_big
They are available in wattages up to 1KW
J-Frog
Negative « Reply #4 on: November 08, 2006, 08:10:12 PM » Author: J-Frog
If burned horizontally (for universal lamps), arc tube eventually bulges and lamp can explode and sometimes it will bulge severly and become paper thin and then break.
Example
« Last Edit: November 08, 2006, 08:13:04 PM by Jace the TudorMan! » Logged
Jeremiah The Bullfrog
TudorWhiz
Negative « Reply #5 on: November 08, 2006, 08:30:43 PM » Author: TudorWhiz
Does not last as long as HPS or MV
mr_big
Positive « Reply #6 on: November 08, 2006, 08:35:19 PM » Author: mr_big
Has excellent color rendering
don93s
Negative « Reply #7 on: November 08, 2006, 08:58:30 PM » Author: don93s
Poor lumen maintenence...unless more money is spent for costly special bulbs/fixtures.
« Last Edit: November 08, 2006, 09:01:43 PM by Jace the TudorMan! » Logged
TudorWhiz
Negative « Reply #8 on: November 08, 2006, 09:04:43 PM » Author: TudorWhiz
They blow up at end of life and are messy to work with from all of the broken glass
Silverliner
Rare white reflector
Negative « Reply #9 on: November 08, 2006, 09:21:25 PM » Author: Silverliner
Metal halide lamps are a maintenance NIGHTMARE! Been through there...
« Last Edit: November 08, 2006, 09:31:27 PM by Mercs rule!!! » Logged
Member of L-G since 2005.
Electrician.
don93s
Negative « Reply #10 on: November 08, 2006, 09:24:44 PM » Author: don93s
They have random color changes.
« Last Edit: November 08, 2006, 09:29:12 PM by don93s » Logged
dp
Positive « Reply #11 on: November 09, 2006, 10:11:33 AM » Author: dp
Certain types can replace HPS without changing or modifying control gear. Mostly applies to Philips CDM\CDOs
« Last Edit: November 09, 2006, 10:13:53 AM by Jace the TudorMan! » Logged
don93s
Negative « Reply #12 on: November 09, 2006, 12:12:45 PM » Author: don93s
Arc in the tube can become unstable and oscillate or swirl and periodically extinguish.
AE125Series
Negative « Reply #13 on: November 09, 2006, 12:52:15 PM » Author: AE125Series
Metal Halide only has 10,000 to 20,000 hours which is not good enough.
« Last Edit: November 09, 2006, 04:49:02 PM by AE125Series » Logged
don93s
Negative « Reply #14 on: November 09, 2006, 06:09:11 PM » Author: don93s
They have the longest restrike time after power interruption.
