Author Topic: Which lamp is older?  (Read 5497 times)
RadiantMV
Which lamp is older? « on: May 30, 2022, 07:12:40 PM » Author: RadiantMV
2 cleartop 400 watt westy lifeguards, one of which I will get in a trade. My question is, if anyone can date by etch, which one is older and what is the exact year?
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: Which lamp is older? « Reply #1 on: May 30, 2022, 07:16:57 PM » Author: HPS_250
The H33-1-GL/DX is definitely older since it was made before the 400w lamps were called H33GL-400/DX as they still are. If I remember correctly it’s likely from the 60s to around 1972/73. Unfortunately I don’t know the exact dates from the etches though, I’m sure some other members do.
LightbulbManiac
My first E14 globe CFL dismantled
Re: Which lamp is older? « Reply #2 on: February 21, 2024, 04:44:12 AM » Author: LightbulbManiac
The only date code I could decode is for the second lamp since on the first one I can't clearly see the date code.
57 = May 1967/1977
I mainly collect Greek-made incandescent lamps, Neon glow lamps, Fluorescent lamps/CFL, and HID, LPS and early LED lamps.
Re: Which lamp is older? « Reply #3 on: February 24, 2024, 12:56:10 PM » Author: wide-lite 1000
 I'm gonna say the bottom one is older as the top one has the "R" in the etch . In the US at least , the "R" came out in the early 80's as a designation of a standard Mercury Vapor lamp.
BT25
Re: Which lamp is older? « Reply #4 on: February 29, 2024, 03:54:41 PM » Author: BT25
Top is from January, 1981.
Bottom is from May, 1967.
Re: Which lamp is older? « Reply #5 on: February 29, 2024, 04:33:20 PM » Author: wide-lite 1000
 I figured someone else could give a more detailed answer as to the dates .
