Author Topic: Japanese 100V CFLs  (Read 1074 times)
Patrick
Webmaster
LightingGallery
Japanese 100V CFLs « on: May 14, 2022, 11:44:17 AM » Author: Patrick
Do any of you know how 100V 50/60Hz electronic self-ballasted CFLs from Japan would perform on 120V 60Hz?  Would a 100V transformer/converter be needed to avoid burning out the ballast?
Patrick C., Administrator
Re: Japanese 100V CFLs « Reply #1 on: May 14, 2022, 12:42:13 PM » Author: dor123
Electronic CFLs can works on both 50-60hz, but can't work on wide range of mains voltage like programmed start electronic ballasts, so I think the ballast may be overdriven.
Re: Japanese 100V CFLs « Reply #2 on: May 14, 2022, 01:54:45 PM » Author: Rommie
The frequency shouldn't be a problem, but over-voltage may be. I always run things like this (220V lamps and ballasts) from either the Variac or a small step-down transformer, I have one rated at 150W that was designed to allow Japanese 200V ballasts to run on 220-230V, it works well stepping our higher 245V down to 220V or so.
Re: Japanese 100V CFLs « Reply #3 on: May 15, 2022, 02:23:21 PM » Author: WorldwideHIDCollectorUSA
For safety’s sake, I would recommend using the lamp on a variac set to 100v since the electronic ballasts do not mind the frequency as much as magnetic ballasts use. I do have some Japanese 100v 50hz/60hz electronic ballasts intended for 2 FPL36 CFL lamps that I have not energized yet because I do not want to risk destroying them on 120v mains.
« Last Edit: May 15, 2022, 02:35:31 PM by WorldwideHIDCollectorUSA » Logged
Re: Japanese 100V CFLs « Reply #4 on: May 15, 2022, 02:42:56 PM » Author: joseph_125
Another option if you plan to do this often is to get a transformer and wire it for a buck configuration. According to the instructions, that particular model transformer can handle 800VA wired in a 120 > 100v buck configuration.
Now if you're just hoping to run a single CFL, you can get lower wattage models that are prewired and are only around the size of a small power brick.
Re: Japanese 100V CFLs « Reply #5 on: May 15, 2022, 04:41:49 PM » Author: funkybulb
U can take any control transformer from a Junk A/c unit as most are
 120 to 24 volts.  Most around 40 VA that is perfect for japan CFLs
  All you got do is wire them as buck transformer drop it down to 96
  Volts.   Unless u have a older outdated electric service from the 1920s  it might put out 110 volt.  But some electronic CFLs  can take higher voltage but it can be risky .  If not I have hundreds of those 120 to 24volt transformer.
bulb_tester2009
Re: Japanese 100V CFLs « Reply #6 on: June 12, 2022, 11:13:29 PM » Author: bulb_tester2009
I have an electronic ballast fluorescent bulb from NEC (nominal 15W 100V 50/60Hz) and I use the 220V to 110V transformer I bought to run it. The measured power is 16W, and there is almost no overcurrent.
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
