Author Topic: Tulamp 400W MV ballast?  (Read 5583 times)
RichD
Tulamp 400W MV ballast? « on: December 18, 2009, 11:46:42 PM » Author: RichD
Has anybody ever seen a tulamp 400w MV ballast? Does such a thing even exist?
tmcdllr
Re: Tulamp 400W MV ballast? « Reply #1 on: December 19, 2009, 12:52:29 AM » Author: tmcdllr
I believe they do, I remember reading about it years ago, but don't know how they work. I want to say it' a lead/lag type but I'm not sure.
Re: Tulamp 400W MV ballast? « Reply #2 on: December 19, 2009, 05:17:03 AM » Author: Medved
I think it would be nothing more then two ballasts in one box.
Exception might be ballast designed for 480V, where one reactor serve two lamps in series.
tmcdllr
Re: Tulamp 400W MV ballast? « Reply #3 on: December 19, 2009, 05:55:37 AM » Author: tmcdllr
Yes, they do exist. Here is one example , although no information is given how it works and I think the pic might be wrong, as this site seems to use the same pic for all of the ballasts.
FGS
Rory Mercury!
Re: Tulamp 400W MV ballast? « Reply #4 on: December 19, 2009, 11:18:10 AM » Author: FGS
They (Advance Ballast) have one for MH. Tulamp MH in a PDF file. That one is HEAVY! almost 60 pounds. They make them for either 120v or 277v. A 480v tulamp ballast do exist if desired.
RichD
Re: Tulamp 400W MV ballast? « Reply #5 on: December 19, 2009, 06:54:32 PM » Author: RichD
Awesome! Thanks for the responses and information. You guys are the best!!!!
don93s
Re: Tulamp 400W MV ballast? « Reply #6 on: December 19, 2009, 07:06:47 PM » Author: don93s
Yes, they are basically one ballast with about 480-500v output for two lamps in series for MV.
RichD
Re: Tulamp 400W MV ballast? « Reply #7 on: December 27, 2009, 09:11:22 PM » Author: RichD
Do any of you have a pic of one of these fixtures?
