February 06, 2025, 07:23:28 AM
Modern
Wow...
Topic: Wow... (Read 3281 times)
KEDER
Wow...
« on: December 09, 2009, 01:45:53 AM »
KEDER
IT is -20 degrees outside tonight... COLD!!! My 175w MV lamp wont even FIRE UP in its ballast!
Gosh.... very cold. i wonder if the cold messes up the lit lights!
would they?
lite_lover
Darren
Re: Wow...
« Reply #1 on: December 09, 2009, 02:12:19 AM »
lite_lover
That's cold,yes the cold will effect the start-up of some lamps,especially the Chinese ones.
The brighter the better.
Re: Wow...
« Reply #2 on: December 12, 2009, 09:52:40 PM »
I've noticed it with Regents, but also with Philips lamps. The Philips lamp that came with my first mercury vapor fixture refused to start if it was colder than -15°F. I replaced it with a deluxe white GE and had very few problems with it.
What kind of bulb is in your 175w MV?
KEDER
Re: Wow...
« Reply #3 on: December 13, 2009, 12:57:03 AM »
KEDER
This one:
CLICKY HEREY
That picture is the lamp that is in there. the pic was taken before it was IN there though.
But it has warmed up a lot since then.
ATM it is +20 degrees. 40 degrees warmer than that night. the cold front is gone now. FINNALY.
Re: Wow...
« Reply #4 on: December 19, 2009, 01:20:58 PM »
The Philips mercury lamps supplied with AE/Electripak fixtures where known to be problematic in cold weather. Around here, it is a common sight to see such security lights with stuff over the photocells to keep the lights on in cold weather. Same holds true for Caster and Regent lamps.
Parrot
YouTube: Parrot175
Re: Wow...
« Reply #5 on: January 11, 2010, 07:38:39 PM »
Parrot
Have you tried a lifeguard bulb I think it would work better then the Chine ones.
