Author Topic: What ballast/fixture can work with Aqueon CFL tubes (PL-L)?  (Read 804 times)
N3210
lightbulb
UCo_R9kHfa7voRrydT2NJYnw tomloveslighting
What ballast/fixture can work with Aqueon CFL tubes (PL-L)? « on: April 11, 2022, 02:25:20 AM » Author: N3210
I found several similar looking tubes in basement (aforementioned in my gallery)
They all appear to have straight pin (in attachment)
Google searching doesn't return anything, just ballasts for the 4 pins (I don't own them)
Lighting enthusiast from San Francisco.
I upload plenty to here, YouTube, and Instagram
!! If I am quiet here, check either my Instagram or my YouTube !!
Re: What ballast/fixture can work with Aqueon CFL tubes (PL-L)? « Reply #1 on: April 12, 2022, 11:40:31 PM » Author: WorldwideHIDCollectorUSA
I believe that an electronic ballast designed for 5 foot F58T8 fluorescent tubes would work best for these 65w PL-L CFL lamps since both these CFL lamps and F58T8 fluorescent tubes run at 100v 0.67a.
Here is a F58T8 electronic ballast that should run this CFL lamp quite well:
https://www.ebay.com/itm/124082352280
If I had one of those, I would use a 50w M110 pulse start metal halide ballast as a preheat ballast without the ignitor connected but with a European Philips S10 starter connected between the center pins since 50w M110 pulse start metal halide lamps run at 85v 0.68a, which would be a close match for these CFL lamps, but I would not recommend using these CFL lamps on magnetic preheat circuits because the electrodes would wear out much faster since such lamps are designed for electronic ballasts.
