Author Topic: I need help with a capacitor  (Read 3662 times)
RadxD461
I need help with a capacitor « on: April 08, 2022, 01:10:08 PM » Author: RadxD461
My 24 MDF 400 volt ac capacitor just blew up on me when I turned on my 400 watt mercury vapor lamp. I was wondering if I can use a 25 MDF 440 V capacitor instead. Will that work?
Re: I need help with a capacitor « Reply #1 on: April 08, 2022, 02:50:18 PM » Author: Alex
Hello,
yes it should be okay, most capacitors anyway have a ±5% tolerance.
best regards
Re: I need help with a capacitor « Reply #2 on: April 08, 2022, 08:38:25 PM » Author: Mandolin Girl
I agree with Alex, that capacitor will be fine.  :bulbman:
Re: I need help with a capacitor « Reply #3 on: April 09, 2022, 03:53:28 AM » Author: dor123
What is your ballast: HX or CWA (HX don't requires the capacitor for proper operation as CWA requires)?
Re: I need help with a capacitor « Reply #4 on: April 09, 2022, 09:37:07 AM » Author: Rommie
With the capacitor being rated at 400V, it's more than likely a CWA ballast. Even if it isn't, it's good practice to ensure the power factor is as high as possible, even if it isn't strictly speaking required.
RadxD461
Re: I need help with a capacitor « Reply #5 on: April 09, 2022, 10:04:29 AM » Author: RadxD461
CWA
Re: I need help with a capacitor « Reply #6 on: April 09, 2022, 05:09:55 PM » Author: joseph_125
24uF 400V is the typical capacitor rating for 400w MH probe start CWA ballasts. It's also uncommon to see a 400w probe start MH ballast here that isn't a CWA.
Re: I need help with a capacitor « Reply #7 on: April 09, 2022, 05:23:14 PM » Author: Rommie
Am I the only one here who puts the proper symbol µ in when saying microfarad..?
Ok, I'm not really serious and I know what it means when people just use a u, but my OCD kicks in sometimes  :lol:
Oh Perry, it's MFD if you're using caps, not MDF, that's something they make shelves out of  :mrg:
I'll get me coat...
Re: I need help with a capacitor « Reply #8 on: April 09, 2022, 06:38:48 PM » Author: joseph_125
Heh, it's mostly because the keyboard I have doesn't have a keypad which means I can't use alt codes for the symbols (not that I remember the codes anyway) and copying and pasting is a bit tedious for short replies.
Re: I need help with a capacitor « Reply #9 on: April 09, 2022, 06:45:46 PM » Author: Mandolin Girl
The Alt codes don't work here, I've just tried but the one for µ is 00B5, which can be followed by [alt] + x to get it to work or type that code into the search box on the character map to bring it up.  :wndr:
Hope that helps.  :-*
