Author Topic: When a fluorescent tube loses vacuum, does it release mercury?  (Read 1425 times)
When a fluorescent tube loses vacuum, does it release mercury? « on: April 04, 2022, 04:21:31 AM » Author: WorldwideHIDCollectorUSA
After knowing that some fluorescent tubes lose vacuum when they go EOL, I wonder if they release any mercury vapor and any buffer gases like argon into the surrounding environment just like they would if they get broken.
Rich, Coaster junkie!
Re: When a fluorescent tube loses vacuum, does it release mercury? « Reply #1 on: April 04, 2022, 05:39:12 AM » Author: AngryHorse
I would say so?, if air has got in somewhere then the contents of the tube can get out the same way, although I wouldn’t say it’s in any high amount to be dangerous?
I had an 11 watt CFL in my pocket a couple of weeks ago, and knelt down to pick something up, breaking the tube in my pocket in the process!
Didn’t get any adverse effects from it though  ;)
« Last Edit: April 04, 2022, 05:42:29 AM by AngryHorse » Logged
Current: UK 230V, 50Hz
Power provider: e.on energy
Welcome to OBLIVION
Re: When a fluorescent tube loses vacuum, does it release mercury? « Reply #2 on: April 04, 2022, 08:05:15 AM » Author: sol
Once the vacuum loss is complete, the pressure equalises between the inside and outside of the lamp.  There is not really anything to force the mercury out of the lamp so the risk is minimal. However, there is an opening so it is not impossible…
Re: When a fluorescent tube loses vacuum, does it release mercury? « Reply #3 on: April 04, 2022, 08:08:48 AM » Author: Rommie
The amount in a single lamp isn't really worth worrying about. If you smash a pallet-load of lamps then yes, but one tube or CFL isn't going to kill you.
Re: When a fluorescent tube loses vacuum, does it release mercury? « Reply #4 on: April 04, 2022, 08:29:01 AM » Author: dor123
The pressure in the lamp is very low, so when the lamp losing vacuum, nothing escape, but air leaks in instead.
Re: When a fluorescent tube loses vacuum, does it release mercury? « Reply #5 on: April 04, 2022, 02:29:10 PM » Author: AngryHorse
I was more concerned about the lamp than my own health!  :lol: :lol:, I was gutted I’d broke a GE Biax, something I now consider as ‘rare’!  ::) :cflstickhd:
Welcome to OBLIVION
bulb_tester2009
Re: When a fluorescent tube loses vacuum, does it release mercury? « Reply #6 on: May 13, 2022, 03:00:19 AM » Author: bulb_tester2009
But the amalgam capsule inside the lamp, once broken, can create dangerous metal leaks
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
Re: When a fluorescent tube loses vacuum, does it release mercury? « Reply #7 on: May 13, 2022, 03:22:36 AM » Author: Medved
The amalgam pellet would have to be leached by some water or so. Otherwise the amalgams generally tend to attract the mercury back, so I would not be affraid that much
