Author Topic: About coloured MH  (Read 1611 times)
bulb_tester2009
About coloured MH « on: March 28, 2022, 01:15:39 AM » Author: bulb_tester2009
Do you have color MH lights, you can list the relevant information to provide me with purchase advice, thank you! :tumh:
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
Re: About coloured MH « Reply #1 on: March 28, 2022, 01:00:13 PM » Author: Alex
Hello,
I have several coloured MH lamps. Green and Blue lamps are very nice, orange ore pink are a bit washed out in my opinion. I have lamps by BLV (Ushio) Osram and some of those cheap that were once available on aliexpress. The last one are worthless, the colours are very fade, the life rather short-a waste of money. Save your earnings and by the more expensive quality lamps by manufacturers that have experience in this field and decent quality. Maybe some of the older ya-ming stuff in your case. If you can, buy BLV/Ushio ones they are some of the best.
If you want however deep intensive colours i.e. for landscape lighting I would recommends good coloured LEDs.
Best regards
Re: About coloured MH « Reply #2 on: March 29, 2022, 01:12:48 AM » Author: tolivac
Its been several years ago-wanted to order some color MH lamps from Venture Lighting-the bulbs were VERY expensive-had to be custom made and their life was shorter than standard halide lamps.Don't know about how to get these at present.Figure they are being replaced by LEDS anyway.
bulb_tester2009
Re: About coloured MH « Reply #3 on: March 30, 2022, 01:27:34 AM » Author: bulb_tester2009
Hello,
Best regards
Thank you for your reply, can you provide me with photos? But in China you can only buy Yaming's colored metal halide lamps.
 :hps::hps::hps:
Note:
bulb_tester2009
Re: About coloured MH « Reply #4 on: March 30, 2022, 01:30:50 AM » Author: bulb_tester2009
In China, customized MH has not disappeared, the price is more expensive, but the life expectancy is similar to normal MH
 :hps::hps::hps:
Note:
arcblue
Re: About coloured MH « Reply #5 on: April 22, 2022, 11:56:39 PM » Author: arcblue
Blue 400w
Green 400w
Magenta 400w
These are also available in 1000w versions but cost about twice as much. Nonetheless this is a lot cheaper than they used to be, but it's remaining old stock.
Look at their "specialty/other" categories to find the 1000w versions; the colors have the same lamp suffixes (BDX=blue, GDX=green, MDX=magenta). They also have 250w tubular aquarium metal halides in 10,000K, 14,000K and 20,000K.
I'm lampin...
Re: About coloured MH « Reply #6 on: April 23, 2022, 01:19:42 AM » Author: dor123
I've 10000K and 14000K 70W R7s MH lamps that I bought at Aliexpress. The 10000K one have rare-earths for some reasons, but the 14000K have indium similar to blue MH lamp, and reach pure blue color during run-up.
mdcastle
mdcastle 26956281@N02
Re: About coloured MH « Reply #7 on: April 24, 2022, 11:20:44 AM » Author: mdcastle
What colors were available and in what wattages?
bulb_tester2009
Re: About coloured MH « Reply #8 on: April 25, 2022, 10:02:33 PM » Author: bulb_tester2009
There are green, blue and rose red, and the wattage is 70W, 150W, 175W and 400W, of which 70W and 150W are double-ended metal halide lamps, 175W are E27 tubes, and 400W are E40 tubes or bulbs
 :hps::hps::hps:
Note:
