Author Topic: Self-ballasted mercury vapor/halogen ballast  (Read 5492 times)
tmcdllr
Self-ballasted mercury vapor/halogen ballast « on: November 29, 2009, 05:25:44 AM » Author: tmcdllr
I never knew one of these existed, seems like a very good idea. I would like to see these be more available and in a broader range of wattages.
Here is the info on it found at this link:
http://lamptech.co.uk/Spec%20Sheets/XingJi%20HMB500.htm
"Self-ballasted mercury lamps have been on the market since their invention in 1935 by Siemens Bros in England, and traditionally they have always consisted of a bare tungsten filament inside the outer jacket of the mercury lamp.
This results in a compromise since the filament and the arc tube both have different requirements for the gas filling in the outer jacket.  The arc tube functions most efficiently if the gas filling pressure is low, to provide good thermal insulation, and additionally nitrogen has to be used since it will not break down in the regions where a high electric field strength may be present.
The filament however requires a high gas filling pressure to extend its life by reducing the rate of tungsten evaporation.  A high molecular weight gas such as argon is also beneficial, but is not compatible with the mercury arc tube.  So a compromise has to be made and self-ballasted mercury lamps usually contain nitrogen at a pressure in excess of 500 torr for the outer jacket.
In 1962 Osram-GEC showed a prototype lamp in which these problems were overcome by employing one of the newly developed linear halogen lamps as the ballast.  The halogen ballast also boosted the total luminous flux of the lamp and improved the red colour rendering ratio, but in those early halogen days it was deemed too expensive to commercialise the idea.  It was not until 2002 that a number of Chinese companies again picked up the idea, and now the halogen ballast is used almost universally among smaller companies.  The halogen technology allows the customer to choose either increased luminous flux or a long-life mercury blended lamp."
« Last Edit: December 01, 2009, 12:04:29 AM by pjc » Logged
HMJMAKER01
Re: Self-ballasted mercury vapor/halogen ballast « Reply #1 on: November 29, 2009, 08:32:21 PM » Author: HMJMAKER01
its still Terribly inefficent! :(
tmcdllr
Re: Self-ballasted mercury vapor/halogen ballast « Reply #2 on: November 29, 2009, 09:15:40 PM » Author: tmcdllr
The Chinese don't seem to think so. In fact, mercury vapor in general is still a very popular light source in China. With this lamp one drawback I see is the arc tube and halogen lamp are offset so this may cause problems with optics. However, with both sources illuminated that might solve that problem.
It may be inefficient but it's mercury vapor and the innards still look cool.
KEDER
Re: Self-ballasted mercury vapor/halogen ballast « Reply #3 on: November 29, 2009, 11:59:48 PM » Author: KEDER
Would this be more efficient than just halogen?
or is it less efficient?
tmcdllr
Re: Self-ballasted mercury vapor/halogen ballast « Reply #4 on: November 30, 2009, 01:33:17 AM » Author: tmcdllr
My guess would be only slightly more as the halogen source would be brighter and more efficient than the tungsten filament, and last a little longer too.
Re: Self-ballasted mercury vapor/halogen ballast « Reply #5 on: November 30, 2009, 10:13:30 PM » Author: icefoglights
Centering doesn't look any worse than the double-tube HPS bulbs.  And you have to remember that SBMV were developed to combine the efficiency of standard life incandescent lamps with the like of extra long life incandescent lamps.
tmcdllr
Re: Self-ballasted mercury vapor/halogen ballast « Reply #6 on: December 01, 2009, 10:41:35 PM » Author: tmcdllr
....so then this should take it one step further with slightly longer life because of the halogen lamp.
Re: Self-ballasted mercury vapor/halogen ballast « Reply #7 on: December 02, 2009, 01:02:13 AM » Author: Medved
I don't think so, as the practical life is mainly imposed by (arctube) lumen loss and this would be the same, or even worse, taking into account higher inrush current of the halogen capsule. I think the only advantage might be the efficacy due to more freedom in outer gas filling, but i'm not sure if this is utilized properly on this particular lamp...
