Author Topic: Finding a lamps arc voltage  (Read 1562 times)
Bean
Finding a lamps arc voltage « on: February 21, 2022, 09:19:06 PM » Author: Bean
Since an f4t5's are voltage is 29vac, would an f8t5 be 58vac?
Or would it be volts per like inch between filaments? in that case about 5vac per in.
Or can it be multiplied from the wattage? In this case w*7.25
What would be the arc voltage of an f10t8 and f10t12?
Re: Finding a lamps arc voltage « Reply #1 on: February 21, 2022, 10:36:54 PM » Author: funkybulb
Arc volt is measured from two points at the lamp such as both ends of flourescent  tube while running.   Problem is domt expect starter to work on second lamp in series. Unless the starter is across both lamps at once.  As it takes about 85 volt to trigger the starter. The most I ever got lit is 4 tubes in series on manual preheat on 128 volt
 Line voltage.
Bean
Re: Finding a lamps arc voltage « Reply #2 on: February 22, 2022, 06:52:35 AM » Author: Bean
How would you measure it from the two ends?
Re: Finding a lamps arc voltage « Reply #3 on: February 22, 2022, 08:26:57 AM » Author: funkybulb
On preheat u can measure it by removing starter while lit.  And I use a modifeid starter with my meter probe leads soldered to starter pin.
This allowed me do quick safe arc voltage check of fluorescent lamp
 In a preheat fixture.
Bean
Re: Finding a lamps arc voltage « Reply #4 on: February 22, 2022, 08:48:08 AM » Author: Bean
The right test equipment helps, I use this, which can show both voltage and current on the same display. You just put the fork around one of the wires to the lamp and connect the black probe to ground.
Yeah it's expensive, but I'm a test gear junkie, that's my excuse and I'm sticking to it  :mrg:
Re: Finding a lamps arc voltage « Reply #5 on: February 22, 2022, 06:47:30 PM » Author: Rommie
@funkybulb Then test ac voltage on the two empty pins?
@Rommie Can I just connect the red one to the ballast output and common to ground?
Bean
Re: Finding a lamps arc voltage « Reply #6 on: February 22, 2022, 06:50:39 PM » Author: Bean
You could, but a safer way is to just connect the black lead to ground and then put the live (hot) wire to the lamp in the open fork. That will give you lamp current and voltage on a single display and you don't have to make contact with any live wires.
It's an expensive piece of equipment, but it's useful for a lot of things. I wouldn't justify buying it just for this  ;D
Re: Finding a lamps arc voltage « Reply #7 on: February 22, 2022, 07:48:31 PM » Author: Rommie
I'm guessing hot is red. I should then use amps and voltage to find watts?
Bean
Re: Finding a lamps arc voltage « Reply #8 on: February 23, 2022, 05:25:13 AM » Author: Bean
Almost, as it's an AC inductive circuit then what you actually get is VA (volt-amps) which is apparent power and is always a higher figure. You need to multiply this by the power factor to get actual watts.
Using this actual tester, the red (hot) probe would not be connected.
Bean
Re: Finding a lamps arc voltage « Reply #9 on: February 23, 2022, 06:03:16 PM » Author: Bean
Oh, okay.
