Author Topic: Will ballast bypass LED lamps get damaged if they are used on magnetic ballasts?  (Read 1286 times)
Will ballast bypass LED lamps get damaged if they are used on magnetic ballasts? « on: February 17, 2022, 12:58:52 PM » Author: WorldwideHIDCollectorUSA
As I have seen that some European LED retrofit tubes are designed for both operation on electromagnetic preheat fluorescent tube ballasts and direct mains voltage, I am starting to wonder whether North American “ballast bypass” LED retrofit tubes for fluorescent fixtures and “ballast bypass” LED retrofit lamps for HID fixtures will get damaged if used on electromagnetic ballasts that provide an OCV that matches their rated mains voltage even if fluorescent starters and HID ignitors are cut out of the equation. I would like to see if anyone knows anything about this.
musictomyeyes
Re: Will ballast bypass LED lamps get damaged if they are used on magnetic ballasts? « Reply #1 on: February 17, 2022, 07:52:42 PM » Author: musictomyeyes
"It depends."  Maybe or maybe not, bi-pin retrofits vary.
Slimline (Fa8 base) should "just work".
A rapid start ballast could be damaged by a retrofit LED faux-fluorescent tube.  Some LED retrofits have shorted/shunted/tied-equipotent base bi-pins, which could over-conduct, overload, rapid start heater windings.
Given your conditions (matching OCV, not-rapid start, sans starters and igniters), a retrofit tube should tolerate and operate correctly.  Says I: I opine, the faux-fluorescent retrofit should tolerate transients and brownouts; otherwise, it is a lousy article, unfit for purpose, a waste of our planet.
Re: Will ballast bypass LED lamps get damaged if they are used on magnetic ballasts? « Reply #2 on: February 18, 2022, 09:41:56 AM » Author: funkybulb
  On RS it good way to take out heating transformer section
And it wont light
Re: Will ballast bypass LED lamps get damaged if they are used on magnetic ballasts? « Reply #3 on: February 18, 2022, 11:21:30 AM » Author: Medved
If the LED supply voltage matches the ballast OCV, plus given the LEDs operate at less than 1/2 power than the original discharge, the chance for the LEDs to work well are very high.
The question is, how the ballasts tolerate the nearly open load condition for long periods of time. Some topologies may result into primary overheating or higher than rated mains current draw (so overcurrent issues in the installation). Mainly the high power factor ones may be problematic in this way.
bulb_tester2009
Re: Will ballast bypass LED lamps get damaged if they are used on magnetic ballasts? « Reply #4 on: March 01, 2022, 08:23:17 AM » Author: bulb_tester2009
I feel that as long as the lamp tube dedicated to magnetic ballasts can ensure life expectancy, ordinary double-terminal tubes must not be connected and are easy to break down. :veolfl: :veolfl:
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
