Author Topic: Where did you get your Philips SL?  (Read 1269 times)
bulb_tester2009
Where did you get your Philips SL? « on: February 08, 2022, 08:04:54 PM » Author: bulb_tester2009
I am now looking for a channel to buy magnet ballasting CFL, can you tell me where do you bought it? SL9W is preferred. :a_sl:
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since.
 :hps::hps::hps:
One of the few Chinese users here
Note:
Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
waterbug
Re: Where did you get your Philips SL? « Reply #1 on: February 09, 2022, 03:35:31 PM » Author: waterbug
There is plenty on Ebay UK, make sure you go to the setting and change the country/region to United Kingdom, because I couldn't find them anywhere else besides UK sellers and the 240v electrical system.
I saw plenty of 80s MK2, those are high quality lamps.
bulb_tester2009
Re: Where did you get your Philips SL? « Reply #2 on: February 09, 2022, 07:19:28 PM » Author: bulb_tester2009
I find SL9!
« Last Edit: February 09, 2022, 07:22:04 PM by bulb_tester2009 » Logged
 :hps::hps::hps:
Note:
Re: Where did you get your Philips SL? « Reply #3 on: February 10, 2022, 04:25:35 PM » Author: James
Philips also sold a lot of the early SL* lamps in Malaysia and Indonesia.  Maybe that could be a cheaper source for you because of the proximity to China?
bulb_tester2009
Re: Where did you get your Philips SL? « Reply #4 on: February 10, 2022, 08:51:11 PM » Author: bulb_tester2009
However, due to the epidemic, I can't buy it abroad, and it is unnecessary. China attaches great importance to epidemic prevention and control.
 :hps::hps::hps:
Note:
Re: Where did you get your Philips SL? « Reply #5 on: February 11, 2022, 02:02:50 PM » Author: Alex
Hello,
I do not know if the prismatic was actually ever imported to china. If it was likely only in small quanitites. i personally found most my prismatics in the lamp recycling bin. Sadly I do not think that helps you. I think you have to wait until this scrap is over to buy one on the internet or to maybe swap, buy one from a member here, who will post to china. If you still want a magnetic ballasted CFL, I think several Japanese Manufacturers exported some in the 80s and 90s to china, they might actually be mo0re common on your place of the world compared to were I am.
Best regards,
bulb_tester2009
Re: Where did you get your Philips SL? « Reply #6 on: February 11, 2022, 06:31:09 PM » Author: bulb_tester2009
其实在中国很难买到,人家都是从外国带来的
Actually, it's hard to buy in China, they bring it from abroad
Leo Yuan
 :hps::hps::hps:
Note:
