Author Topic: What will happen to MH and HPS before the end of their lives?  (Read 1396 times)
bulb_tester2009
What will happen to MH and HPS before the end of their lives? « on: February 05, 2022, 09:08:52 PM » Author: bulb_tester2009
I know :a_mh: MH The arc will turn green at the end of life, the arc tube will bulge, and the arc tube will crack after a long time of bulge. When the arc tube cracks, :a_mh: MH will die. But I don't know what will happen to  :a_son-t: HPSCan you tell me?
« Last Edit: February 05, 2022, 09:11:53 PM by bulb_tester2009 » Logged
:hps: The use of resistor-capacitor drivers or very poor quality LEDs in my collection is prohibited.
bulb_tester2009
Re: What will happen to MH and HPS before the end of their lives? « Reply #1 on: February 05, 2022, 11:57:07 PM » Author: bulb_tester2009
Will the arctube crack?
Rich, Coaster junkie!
Re: What will happen to MH and HPS before the end of their lives? « Reply #2 on: February 06, 2022, 04:16:21 AM » Author: AngryHorse
Only a small percentage of them leak, with HPS, the pressure usually just goes through the roof until their a bright mercury green colour on start up, and then constantly cycle within a very short period of being on.
Current: UK 230V, 50Hz
Power provider: e.on energy
Welcome to OBLIVION
Re: What will happen to MH and HPS before the end of their lives? « Reply #3 on: February 06, 2022, 04:25:51 AM » Author: Medved
The arctube may crack (some defect or when exposed to some vibration stress,...), but with HPS it is nothing violent, the pressure there is just way too low and the tube narrow (so not that big forces involved).
Usually as the HPS arctube blackens over time, it starts to overheat. And because HPS are saturated vapor lamps, overheating leads to the lamp cycling.
But if the arctube leaks and so ignite the discharge in the outer bulb, the outer may shatter and cause hot glass and metal showering down.
bulb_tester2009
Re: What will happen to MH and HPS before the end of their lives? « Reply #4 on: February 06, 2022, 08:38:29 PM » Author: bulb_tester2009
I have seen the explosion of MH. The arctube explosion did not break through the shell, but left black marks in the shell.  :a_mh:
